Old 09-16-2007, 08:00 PM   #1
need: "new construction" book on wiring
I am now dried in on my new house and I had the pros install the meter and 200 amp panel. I am going to take on the outlet and lighting wiring, but I would like to find a book with helpful information. I already bought a book at lowes, but it only had three pages of useful information for new construction. Here are some things I am looking for
1) Number of outlets per room and per circuit
2) size of breaker and wiring for circuits
3) special requirments for kitchens, bathrooms, laundry rooms, and other areas
4) other things I should know before the inspector fails me for them
I've replaced wiring before, but have never planned and wired up a new home. I am the GC for the house so I have some construction experience. I'd rather do my homework on this than be delayed at inspection time. Is there a good book focused mainly on new construction?
Brian
bjherron is offline   Reply With Quote
Old 09-17-2007, 03:35 PM   #2
Electrician philosopher
The NEC is the minimum required in the US. Unfortunately, different jurisdictions( from tiny cities to entire states) modify the code as they see fit before adopting it into law. I'm not suggesting you go out and purchase the NEC as only a percentage of it has to do with dwellings anyway. "wiring Simplified" is a good book which will give the NEC answer in layman's terms to the problem you are describing. I'd also consider (only if it was possible or even desirerable for you) to contact a residential electrician to come "lay out" the house for you. This would involve him (or her) marking on the studs the locations for receptacles and switches to meet the minimum per code and maybe advise you on the "extras". Best of luck to you and make sure all your wirenuts are TIGHT!! . Keep us posted.
Andy in ATL is offline   Reply With Quote
Old 09-17-2007, 03:55 PM   #3
Licensed Pro
Best books are "Wiring a House" by Rex Caldwell and "Electrical Wiring: Residential" by Ray Mullin. Both are available at Amazon.
Old 09-20-2007, 10:51 PM   #4
I bought the wiring a house book, it will be here tomorrow. I also found an electrician that's going to meet me at the house saturday and do a walk-thru explaining what I need/should have for $20/hr. Sweet deal!
Brian
Old 09-21-2007, 03:23 PM   #5
At that price don't get in any rush!!! If he's a good resi. guy that is a goldmine of info and if you can tie him down for 8 hrs. boy-o-boy I would!
More On This Topic
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you Part 2 for drawing an electrical map. Next we are going to draw all of our outlets in our room onto our map. The symbol for an outlet is 2 lines coming out of the... Read More »
Hi! My name is Chad Smith and I'm a state certified Journeyman Wireman basically a electrician and I'm representing expertvillage.com. Today we are installing a new doorbell in our house here. The first step that you should take when you are installing... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Okay, this is a great example of what happens in a lot of basements, where a homeowner starts to do their own work, hires one person to come in and he half... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we will be replacing our outlets and outlet covers. First we need to remove our existing outlets, then we need to clip off our wires and strip them back for our new outlets. Next we need to go... Read More »
Newer, more energy efficient homes have been constructed to seal out the outdoor environment almost 100 percent. This condition allows loaded, stale air to accumulate unless windows are opened. Open windows allow some of the heating or air conditioning... Read More »
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
