Need A Neutral - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2010, 11:15 AM   #1
need a neutral
can i get a neutral from the ground 240 volt 3 phase? The machine is 240 1 phase with neutral.
matts is offline   Reply With Quote
Old 12-20-2010, 11:31 AM   #2
joed's Avatar
Rewards Points: 12,336
No you can not.
Old 12-20-2010, 03:59 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the machine would be 120/240 1, not 240 1 if it requires a neutral.
Old 12-20-2010, 05:21 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
I am sure the service has a neutral, but if you are talking about an existing circuit that is straight 3-phase without a neutral then absolutely not.
What size is the circuit?
What size circuit does the new machine require?
What size is the wire?
To be honest, this is NOT something someone without the proper experience should be messing with. A qualified electrician would not be asking this question.
Speedy Petey is online now   Reply With Quote
Old 12-20-2010, 10:57 PM   #5
" Euro " electrician
frenchelectrican's Avatar
This part you may end up redo this circuit and what kind of three phase supply are you refering to due there are few combations of three phase supply.
What kind machine this is ??
How much power ( amps ) it required ?
What size exsting conductor you have there right now ??
Once we know the basic quesiton we can go from there but the main item is if this is a commercal building the all bets is off that you have to get a electrician to come out anyway.
Merci.
Marc
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
question on the "stubbie" bonding links n175h Electrical 12 10-13-2009 04:09 PM
Main disconnect neutral wiring Daniel Holzman Electrical 5 10-04-2009 01:36 PM
GFCI feeing subpanel question scott2332 Electrical 45 02-28-2009 03:15 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
