Need To Move A Power Outlet ~10" - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2012, 11:51 AM   #1
Rewards Points: 1,050
Need to move a power outlet ~10"
Hello
I am planning to install a shelf in my office but there is an outlet right behind, and I need that outlet to power my PC
I would need to shift the outlet to the right by approx 10", but it is currently installed into a box that is fixed on the left side of a stud
Meaning if I want to go right, there is the stud in the way
How should I do? Drill (with an angle) the side of the box and the stud to reach the other side, and pass the current cable thru that hole?
french_guy is offline   Reply With Quote
Old 12-23-2012, 12:38 PM   #2
Rewards Points: 2,516
unless you have 10" of slack in the existing cable supplying power to the outlet you want to move how do you expect to move the outlet 10"??
You may need to keep the existing box and use that as a junction box placing a blank cover over it.
hammerlane is offline   Reply With Quote
Old 12-23-2012, 12:48 PM   #3
I do not know if I will have enough length.....But i can make an extension and use the current box as a junction box as you said
And yes, I will put a cover plate
My main concern is how do I go across the stud?
Old 12-23-2012, 12:56 PM   #4
You have to remove wood material from the stud....drill a hole
Old 12-23-2012, 01:22 PM   #5
So it will be with an angle, right? (no other choice though....)
What bit should I use?
I am planning to pass 14 gauge cable (2+1)
Old 12-23-2012, 01:29 PM   #6
Engineer
Rewards Points: 161
If you end up at an angle going through the stud that would be fine. They do make flexible drill bits and right angle attachments should you really want to get crazy.
diystephen is offline   Reply With Quote
Old 12-23-2012, 01:32 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
The only way you are going to drill the stud is remove drywall.
Old 12-23-2012, 01:33 PM   #8
Ouch.....!!!!
Old 12-23-2012, 01:57 PM   #9
Engineer
Rewards Points: 161
It should be possible to cut the new outlet hole and use a flexible shaft drill bit (through that newly cut hole) to get through the stud. You can then fish the new wire to the old box.
The Following User Says Thank You to diystephen For This Useful Post:
NJMarine (12-23-2012)
Old 12-23-2012, 03:59 PM   #10
Resi EC
Rewards Points: 252
Just try not to hit the wire on the other side of the stud.
Gac66610 is offline   Reply With Quote
Old 12-23-2012, 04:18 PM   #11
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Kill power to the outlet before attempting
The above suggestion.
sublime2 is offline   Reply With Quote
Old 12-24-2012, 06:26 AM   #12
jbfan's Avatar
Rewards Points: 488
By the time you pay for the flex bit and holder, you can repair lots of sheetrock.
The Following User Says Thank You to jbfan For This Useful Post:
jlmran (12-24-2012)
Old 12-24-2012, 07:44 AM   #13
Seriously?
Just kidding......I am French and not familiar with the US construction code: framing, wall studs, etc...
But I'm used to electricity (220V) and the 1st thing I do before doing anything on my electrical network is to identify the right circuit breaker and shut it down
Don't want to die.....
Old 12-24-2012, 07:50 AM   #14
Resi EC
Rewards Points: 252
Couple other suggestions: before moving receptacle ~10" make sure you do not exceed 12' between it and the next receptacle.
If you have a back on your book shelves it should cover any holes in sheet rock, assuming they will be permanently installed.
Old 12-24-2012, 11:02 AM   #15
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Hello
Can you supply a picture of the shelf, is its design such that it will cover the entire outlet ...receptacle .. or is it the mounting brace that is causing the problem ...
New outlet using power from a nearby switch. surecook Electrical 23 10-16-2009 06:27 PM
pulling power from an outlet smcvey Electrical 6 03-21-2009 03:28 PM
power from outlet to switch lincoln85 Electrical 2 10-09-2008 12:04 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
Outlet and light pigtailed to power. ok? skellies Electrical 2 06-24-2006 01:08 PM
