Old 12-30-2005, 02:13 PM   #1
need to move existing light.
I need to move an existing light fixture in a bathroom. It need's to be moved about 2 feet. It will remain on the same wall that it is attached to. I have a good idea on how to do it, but not sure if it is the correct way, that's why I am here. Can I just leave the existing box and wire nut the extra wire that I need to make up the 2 feet. I am just concerned about covering up the wall where I would make the splice. I would like to do this the correct way. Thanks a lot. Happy New Year
surfsupinhawaii is offline   Reply With Quote
Old 12-30-2005, 03:25 PM   #2
Electrical Contractor
you can leave the exsisting box, but it must remain assessable. You can put a cover over the box and paint to match the wall. If you do not want the box showing, then the only way is remove the wire back to the switch and replace.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 12-30-2005, 08:01 PM   #3
I'm just stirring the:
CGofMP's Avatar
JB - would accessible count if it were accessible via a crawlspace like in the attic? Or must it be from within the dwelling?
CGofMP is offline   Reply With Quote
Old 12-30-2005, 10:11 PM   #4
World famous jerk.
If you can get the end of the wire up into an attic, or down into a crawl space, that's fine. Accessible is the only requirement. "Readily Accessible" is not the requirement. Assessible doesn't even necessarily even mean "easy". As long as you can get to it without damaging the building (such as you would have to do if you buried it behind sheetrock), you're compliant. Here's the definition straight out of the code:
"Accessible (as applied to wiring methods). Capable of
being removed or exposed without damaging the building
structure or finish or not permanently closed in by the
structure or finish of the building."
mdshunk is offline   Reply With Quote
Old 12-31-2005, 12:56 AM   #5
CGofMP's Avatar
mdshunk
World famous jerk.
Okay MD... whats the story with yer new tag line :-)
Old 12-31-2005, 04:22 AM   #6
World famous jerk.
I generally work 12 hour days. I relax and unwind answering forum site questions. Sometimes I'm testy with people in the process because I'm tired. I figured that if I state ahead of time that I'm a jerk, all the cards would be on the table.
Old 12-31-2005, 09:54 AM   #7
Well MD, I've been snooping around some other sites and I pretty certain we all appreciate the time you spend sharing information. I personally would never call you "World Famous":D . You'll probably get bored with us someday but until then, Thanks. HS.
K2eoj is offline   Reply With Quote
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
add a second light to an existing 3 way switch circuit djohns10 Electrical 6 03-02-2007 08:16 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
