Need More Breakers But Panel Is Full - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 09:48 PM   #1
Need more breakers but panel is full
I have a square D QO load panel 200 amp the cover states it cat. No. QOC20U . My problem is all 20 slots are being used and already have piggyback breakers in, I need more slots for add. Breakers. I was wondering if it's possible to change the guts in this panel (that would add slots) or do I need to upgrade the whole panel
Barry1 is offline   Reply With Quote
Old 02-12-2012, 10:00 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
Run a subpanel.
Old 02-12-2012, 10:05 PM   #3
Is that the only option, I'd rather have only one breaker panel
Old 02-12-2012, 10:07 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Buy a 200a 30sp pace QO panel and reuse some of your breakers
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Barry1 (02-12-2012)
Old 02-12-2012, 10:10 PM   #5
Rewards Points: 6,652
It is the easiest option. BTW QOC20U is the part number of the cover, not the actual panel. Can you post a picture of the panel with the door open, and also look behind the panel cover for the actual part# of it.
Old 02-12-2012, 10:17 PM   #6
So I will be able to use exsisting panel?
Old 02-12-2012, 10:20 PM   #7
Is there an echo in here? Yes, if you add a sub-panel. Otherwise, go out and get a larger panel and hire a company to replace the existing, or better yet, let them do it. Reason being, if you have to replace the panel if you do not want a sub-panel, the meter has to be pulled, if the existing panel you have is the main means of disconnect for the incoming feed from the power company (POCO).
The Following User Says Thank You to gregzoll For This Useful Post:
Barry1 (02-12-2012)
Old 02-12-2012, 10:21 PM   #8
Licensed electrician
Rewards Points: 1,268
The entire panel will get changed out.
BTW, I would install the 200 amp 40 circuit and skip the 30 circuit.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Barry1 (02-12-2012), plummen (02-12-2012)
Old 02-12-2012, 10:24 PM   #9
plummen's Avatar
Old 02-12-2012, 10:29 PM   #10
There is nothing wrong with the 30. i just like to leave room for additions at a later time. It would depend on how many circuits the OP needs to add.
Old 02-12-2012, 10:39 PM   #11
plummen's Avatar
I feel the same way but most people think im nuts when they see the 200a 40sp homeline panel in this house with a dozen empty spaces,I try and be optimistic and tell them the basement still isnt done and Ive got dreams of another garage before i die!
Old 02-13-2012, 02:53 AM   #12
Julius793's Avatar
My house will have a 40/60. I always love pulling new lines for stuff.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-13-2012, 11:27 AM   #13
plummen's Avatar
You just like pulling wires in!
Bull Dog Pushmatic Electrical panel and Circuit Breakers highdeserthome Electrical 34 01-27-2012 02:06 PM
Add Breakers to Existing Panel? BusyPete Electrical 8 01-22-2012 10:34 AM
125 amp rated breaker panel yet I have 155 amps worth of breakers??? graysqwrl Electrical 3 08-28-2011 03:25 PM
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
100A Panel is full...I Need more circuits redly Electrical 2 06-20-2005 07:26 AM
