Need For More 12' Power Cords - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-07-2013, 09:46 PM   #16
Rewards Points: 13,300
Then use a core drill bit.
Old 02-07-2013, 09:51 PM   #17
Licensed electrician
Rewards Points: 1,266
Bigskytool has an SDS hammer drill for $40 right now.
Old 02-07-2013, 10:37 PM   #18
Originally Posted by Dorado View Post
I need all the juice and as little heat as I could get. Outlet spacing needs to be considered when designing cord length and it's like nobody knows there are outlets out there spaced so far apart.
I'm just a weekend warrior when it comes to home fixit/improvements, but if I need to use plug-in tools I just keep a 12 gauge extension cord in the work area for all tools (e.g., saws, sanders, my old Dewalt drill, lighting, etc.).
Faster than walking back to the wall outlet for plugging/unplugging each tool and I haven't noticed power issues by adding another 15-20' to the run.
- wader
wader is offline   Reply With Quote
Old 02-08-2013, 08:05 AM   #19
Resi EC
Rewards Points: 252
I want to drill a 1" hole in concrete with a hammer drill. I need all the juice and as little heat as I could get. Outlet spacing needs to be considered when designing cord length and it's like nobody knows there are outlets out there spaced so far apart.
Just make sure the drill you are using is lower than the receptacle its plugged into, 'juice' runs down hill better.
Gac66610 is offline   Reply With Quote
Old 02-08-2013, 08:25 AM   #20
Rewards Points: 3,130
Originally Posted by k_buz View Post
Last week I heard something about someone making a sort of extension cord, for lack of a better term. Anyway, it has prongs on one end, and a single receptacle on the other. The idea is that when you are too far away from an receptacle, you can use this "extension cord" at a temporary solution. From what I remember, they come in a variety of lengths.
Wow, what a novel idea. Wish I'd thought of it.
The Following User Says Thank You to md2lgyk For This Useful Post:
Missouri Bound (02-08-2013)
Old 02-08-2013, 08:38 AM   #21
Rewards Points: 137
We can trade. I have a drill with a 12 ft cord. My outlets are very close together. You may have seen my thread "need for more 2' power cords". I have been getting tangled up in the super long 12' cords and it is becoming a safety hazard. I am also getting a lot of voltage drop at the end of this 12' cord.
Troy32 is offline   Reply With Quote
The Following User Says Thank You to Troy32 For This Useful Post:
mpoulton (02-08-2013)
Old 02-08-2013, 08:48 PM   #22
Idiot Emeritus
Rewards Points: 1,492
I can see the OPs point. Un fact, I saw the point about 30 years ago. Every one of my portable power tools has a 25' cord on it.
Rob
micromind is offline   Reply With Quote
Old 03-02-2013, 03:44 PM   #23
The Ridgid with a 12' cord had a warning about washing after touching it because of lead and I wasn't able to join the Ridgid forum for some reason so I bought the best reconditioned hammer drill I could find - a Bosch HD19-2. Turns out it has a 12' cord but it's not mentioned in the specs or manual. The cord is barely long enough when plugged into the bathroom outlet, just as I calculated.
Dorado is offline   Reply With Quote
Old 03-02-2013, 07:57 PM   #24
Rewards Points: 948
Interestingly I had this same problem just this week.
I bought a 15" planer with a 8' power cord. It wasn't long enough to reach anyplace I could put an outlet. I had some flexible cable, so I tried to change the power cord; but it wasn't obvious how to get the old cord off. So I made a 2' 240v extension cord. Looks silly, but it works.
You might try that.
Toller is offline   Reply With Quote
Old 03-02-2013, 09:03 PM   #25
I already have a one footer. A 13' cord would be ideal, but I think 12' works for me. I actually heed the warnings about using as short a cord as possible, to use extensions only temporarily, etc. I'm even skeptical about the unpluggable cords on some tools. I think hard wired is best.
Old 03-02-2013, 09:38 PM   #26
Rewards Points: 87
I thought it was against code to plug hammer drills into bathroom outlets as the water washes away the juice.
George6488 is offline   Reply With Quote
Old 03-02-2013, 09:44 PM   #27
I could see it being against some code because the light switch powers that outlet and I don't know the consequences of accidentally shutting off the power in the middle of drilling. It's probably more likely to get the bit stuck, and I wonder if it's bad for the tool. I already looked up the amps of 60 watt bulbs and the amps that bathroom light fixtures take and no problems there.
Old 03-02-2013, 10:05 PM   #28
Electrical Enthusiast
Rewards Points: 504
Only if it's not on a GFCI......that way the water and juice will have the same current.
Kyle_in_rure is offline   Reply With Quote
Old 03-02-2013, 10:20 PM   #29
I don't have a GFCI in the bathroom. I'll just keep the seat down and make sure everything is dry.
Old 03-03-2013, 12:44 AM   #30
JOATMON
ddawg16's Avatar
Rewards Points: 1,142
There is a little known secret to making sure extension cords don't zap your power....
Take the cord and make sure there are no loops...you want it as straight as possible. That way you reduce any potential magnetic inductance to a minimum.
Case in point...you know how a transformer works....so when you leave the extension cord coiled up it acts like a transformer and reduces the power available on the load side.
So straighten out that extension cord and let the electrons have a straighter shot at the load.
ddawg16 is online now   Reply With Quote
Power strip hack salex Electrical 3 01-31-2012 07:10 AM
Solar at the cottage? Tito1800 Home Theater 2 01-18-2012 03:30 PM
TV power bridge into existing outlet and protected by an external surge protector andytran73 Electrical 4 12-14-2011 09:00 AM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
