Need A Meter Disconnect Box - Electrical - DIY Chatroom Home Improvement Forum
Old 08-17-2013, 04:19 PM   #1
Rewards Points: 392
Need a meter disconnect box
I have a house built in the 70s that was installed with 125 amp service I called my local Portland General Electric utility and they told me that the wiring would support a 200 amp service to my house. They just told me to get the meter box that has a disconnect built in and to run 3 inch conduit down to the dirt. They would hook it up..
Does anybody have advice on what kind of meter box (part number) I should get? I don't need anything other than a disconnect. I also don't want to put all the breakers here as the actual breaker box is about 30 feet away.
Also how much would it cost if I'm getting a good deal for one of these?
Thanks for any advice!
zootjeff is offline   Reply With Quote
Old 08-17-2013, 04:48 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Go to hd or lowes and get a metermain.
Some have just the main breaker, and some have a few breaker spots.
You will have to change the wire going into the panel you have now to upgrade.
jbfan is online now   Reply With Quote
Old 08-17-2013, 10:24 PM   #3
Philly Master's Avatar
Rewards Points: 516
First your meter box must match whatever specs the POCO deems ..
I am in a area and on the edge of 2 utilities .. they have different specs ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 08-18-2013, 01:11 AM   #4
" Euro " electrician
frenchelectrican's Avatar
First of all check with your POCO to see what type of metermain they will approve for your location the reason why due there are few differnt specifcs they want with it.
Second thing if you going with 200 amp panel it genrally cheaper to buy one with main breaker but .,, get the ground bussbar you may end up get couple depending on numbers of circuits you will use.
Third the conductor between the metermain and panel ( breaker box ) will have to be 4 conductors type like SER or 4 indivual conductors in conduit one of the two will meet this requirement easy.
Merci,
Marc
Old 08-18-2013, 08:23 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I find it very fishy that your POCO knows what the wiring in your house will handle. I wouldn't take their word for it.
2nd Main disconnect jodywoj Electrical 4 03-17-2013 02:03 PM
Please help! Meter socket question fraghouse Electrical 9 11-27-2012 02:36 PM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 07:53 AM
Main disconnect box before service panel Cellomangler Electrical 4 02-04-2008 08:43 AM
