Need Main Panel Advice - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 04:02 PM   #1
Need main panel advice
I'm buying a 1970 house. The main panel is 150 amps, with no ground bus and no main breaker. There is a 60 amp sub panel fed off a 60 amp breaker. Most of the circuits are ungrounded (two wire, no ground) but a few are grounded to the neutral.
Our current house has 150 amp service and it seems to be enough.
I have a friend who is a GC, but not an electrician, who tells me that installing a new panel is no big deal, and the two of us can easily do it (I get the impression he's done it before). I've done electrical things in the past, like outlets and new light fixtures, and even circuits, but a new main panel seems like a different level of skill. Any advice in that regard?
Also, is it a code violation to connect the existing ungrounded circuits to a new panel?
pyper is offline   Reply With Quote
Old 01-30-2011, 04:36 PM   #2
joed's Avatar
Rewards Points: 13,328
I don't know whether you can do it. You friend seems to think he can.
It is not a violation to reconnect ungrounded circuits.
It is a very huge violation the ground a two wire circuit to a neutral.
Old 01-30-2011, 09:20 PM   #3
Yeah, that's why we need to replace the panel -- that, and the lack of a main breaker.
Old 01-30-2011, 09:40 PM   #4
Licensed electrician
Rewards Points: 1,766
Given the vintage of the house you might have a split-buss panel where the top 6 (or less) breakers act as the main to cut the power to the panel.
Old 01-30-2011, 10:09 PM   #5
joed's Avatar
I may have mis read what you meant by grounding the neutral to the ground. At the panel they are bonded together. More accurately at the first disconnect, which is normally the panel, they are bonded.
I thought you meant at the receptacles they were connecting the neutral and ground. That is wrong.
Main panel or sub panel? tbeaulieu Electrical 5 04-07-2010 11:58 AM
Main Panel / Service Upgrades gbe Electrical 12 11-06-2009 11:20 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
Replace main panel or use subpanel? MasterofNone Electrical 8 02-12-2008 12:24 AM
