Closed Thread
Old 01-15-2010, 09:35 PM   #1
need to know what size sub panel to get
i have a 225v main panel and i want to run a sub panel for 13 30amp breakers what size sub panel should i get its for lights that draw 7.5 amps and have 1000w bulbs total of 39 lights the lights are 220v
italy92530 is offline
Old 01-15-2010, 09:46 PM   #2
Inspector/Instructor
codeone's Avatar
Do you mean 225 Amp. panel? What kind of operation are you going to be using?How many lights on each circuit?
codeone is offline
Old 01-15-2010, 09:53 PM   #3
Old 01-15-2010, 10:01 PM   #4
codeone's Avatar
What is the Amperage of your main panel? Why do you need the 13- 30 amp breakers. Are these mogle base lights. how many per circuit?
Your total bulbs 39 x 1000 = 39000 divide by 240v = 162.5 Amps
codeone is offline
Old 01-15-2010, 10:03 PM   #5
225 with transformer 112kv
Old 01-15-2010, 10:03 PM   #6
The numbers and information you have provided is not clear. Please elaborate and provide additional information.
vsheetz is offline
Old 01-15-2010, 10:04 PM   #7
Is this a home? Do you mean you have a 225amp main?
Paelectrican is offline
Old 01-15-2010, 10:07 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
Is this stage lighting?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Stubbie is offline
Old 01-15-2010, 10:07 PM   #9
its a commercial building with a 800amp switch gear with a 112kv transformer and i want to run a sub panel for lights in a room that draw 7.5 amps and have 1000w bulbs total of 39 lights the lights are 220v what size sub panel can i put in the room
Old 01-15-2010, 10:08 PM   #10
Xtreme DIY'r
If they draw 7.5a @240v & you have 39 lights
Bare Min = 7.5a x 39 = 292.5a
So...... ?
Commercial is different rating...so you need more
Scuba_Dave is offline
Old 01-15-2010, 10:12 PM   #11
codeone's Avatar
its a commercial building with a 800amp switch gear. i have a 225amp main panel and i want to run a sub panel for 13 30amp breakers what size sub panel should i get its for lights that draw 7.5 amps and have 1000w bulbs total of 39 lights the lights are 220v
Why do you not have a liscened electrician working on this?
codeone is offline
Old 01-15-2010, 10:18 PM   #12
Old 01-15-2010, 10:21 PM   #13
nap
You talking to me?
nap's Avatar
I would suspect he has a business in his home and is hoping to grow the business. You need to make it light like daylight so as to be able to see what you are doing.
and yes, if this is for a business, California most likely requires a licensed electrician to do the work.
nap is offline
Old 01-15-2010, 10:28 PM   #14
I would suggest you contact a licensed electrician. This is a big job for someone untrained to take on, and believe your state would require you to have one for this application.
Old 01-15-2010, 10:36 PM   #15
so no body knows?
Closed Thread
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 09:17 PM
400 Amp Upgrade / Transfer Switch AndrewF Electrical 50 07-04-2009 08:33 PM
Can I upgrade my main panel? MarkinTexas Electrical 8 01-22-2009 11:15 AM
Upgrade Meter Box Help BenJoeM Electrical 10 10-24-2008 11:58 AM
Service upgrade rondo Electrical 1 05-21-2007 07:19 PM
