#181 | |
UAW SKILLED TRADES
Need to know if my grounds and neutrals are connected rightQuote:
" One nice thing about the NEC articles ... you have lots of choices" Stubbie Last edited by Stubbie; 01-10-2012 at 10:20 PM. |
#182 |
Damn... the light bulb just came on
That Mike Holt diagram was perfect! I've always struggled with bonding and code from an understanding perspective. Parallel neutral currents... Of course! This has got to be the best thread ever! |
#183 |
Need to know if my grounds and neutrals are connected right |
#184 | |
UAW SKILLED TRADES
It also wasn't entirely correct as the conduit from the meter to the panel is not the responsibility of the utility lineman. They do work on stuff that is pretty scary and IMO need bigger
" One nice thing about the NEC articles ... you have lots of choices" Stubbie |
#185 | |||||||||
I ask the impossible!
I haven't read the whole thread, but I think that while some big things have been pointed out, there are some I wanted to cover in case they had not been pointed out. Quote:
Let's set that aside and say you're using 2 gage aluminum. There has been discussion here that the table in NEC that says you can use 2 gage aluminum for 100 amps applies to the service entrance, but for the table that you SHOULD be using 2 gage aluminum can only be used up to 90 amps. You'd need to step down to 4 gage, which I don't know off the top of my head you can get for amperage. My garage subpanel is 100 amps and I'm using 2/0 for both hots and the neutral. I pulled 4 gage copper for my ground PLUS I used metal conduit which is also allowed to be used as your ground conductor if it is continuous between both panels, but that is much more difficult and costly to do. As has been covered very well, you need the ground conductor. You also mentioned it was inside condut for the risers. If your pictures are an indication, assuming you used PVC this conduit should have been schedule 80, schedule 40 is too thin for physical protection. Some inspectors might accept schedule 40, but the NEC can be read as requiring schedule 80. You would need to be buried 24 inches deep or more IIRC for direct burial. Quote:
Regardless, the right thing to do would be that his gets permitted and inspected after the fact. Quote:
If you intend to use 100 amps in the barn, you need to replace your wire. Regardless, you should pull a permit. Your trench will need to be inspected before dirt is put back into it. You need to dig the trench anyway to put in the ground conductor even if you downsize circuit breakers to use the existing wires. And don't even turn on your breaker in the house for this for testing or anything until you pass rough inspection. Quote:
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner. Last edited by WillK; 01-17-2012 at 06:48 AM. Reason: fixed a missing quote tag |
#186 |
This thread has been an incridible read and I've been surfing all day on different aspects of house wiring. I find it so interesting and if I had to do it over again, I'd probably become an electrician.
Here is a link I found while looking at some other sites. It's not totally relevant to what's being discussed here. It's a PPT presentation on the importance of neutrals in a branched circuit and is an example of how voltage could be carried on the ground if the neutral and ground bus of a subpanel were bonded. This put on the light bulb over my head on the importance of neutrals |
| Display Modes | |
| Are grounds and neutrals supposed to touch in the breaker box? | tibberous | Electrical | 7 | 08-13-2011 02:06 PM |
| Grounds and Neutrals, What To Do? (pics inside) | ts46176 | Electrical | 13 | 07-24-2011 02:18 PM |
| rewiring old house-multiple earth grounds | Daneel | Electrical | 9 | 07-17-2011 10:17 PM |
| Double tapped Grounds and neutrals | sarychapina | Electrical | 3 | 06-08-2011 07:35 PM |
| Neutrals and grounds in main panel | steve37887 | Electrical | 6 | 11-12-2009 09:20 AM |
