Need Junction Box, But No Wall Cavity - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2011, 05:51 PM   #1
need junction box, but no wall cavity
I need to install a junction box on an interior wall to install a wall sconce. Problem is that there is no cavity behind the drywall to install the box. there is a triple wide 2x10 header stacked onto a double top plate at the level the box needs to go.
Short of having to cut into the header to recess a standard junction box is there another way to accomplish the same thing?
I was thinking maybe a round light pan like you might see on an exterior light fixture. this thing basically mounts onto the surface of the wall, they the sconce cover plate covers that.
das fisch is offline   Reply With Quote
Old 05-09-2011, 06:00 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
a pan box maybe?
Old 05-09-2011, 06:41 PM   #3
Licensed electrician
Rewards Points: 996
The pancake box pic posted abave can only hold one cable. You will also need some way to recess the cable.
Can I remove this wall..? (Image) findlay70 Building & Construction 8 04-27-2011 06:02 PM
How to calculate total glazing allowed in a wall? dalepres Building & Construction 3 04-22-2011 01:28 AM
Repairing interior wall cavity with mold, what would you do? (Pics included) pendlebg General DIY Discussions 4 06-16-2009 04:40 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
