Need To Install A Sub Panel! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-09-2009, 04:03 PM   #16
OK, wait a minute
You said you were running a sub-panel in the shed
You are only allowed to run (2) circuits MAX to a detached structure, after that it has to be a sub-panel
So you run a main feed - larger wire to the sub panel
Then you run circuits from the sub panel
Do a search on this site for sub panel & do some reading
You can have 100 outlets on a circuit, there isn't a restriction
Any single outlet can handle the breaker/wire rated load
In total power draw you can't exceed the breaker rating or it will trip
Old 10-21-2009, 10:09 AM   #17
I'm back, I've got just a few more questions.
The wiring, both to to the main and from the sub to receptacles, should they be stranded or solid?
If I run a ground rod at the subpanel, can the wire from the ground bar inside the subpanel to the ground rod be 1 or 2 sizes smaller?
In the main, ive got 2 30a circuit breakers (i think its called a 2 pole) already in (when the house was built in '74). Can i run these together to make one 60a breaker as the feed for the subpanel?
dPride is offline   Reply With Quote
Old 10-21-2009, 10:33 AM   #18
Rewards Points: 1,010
Should not really matter
Yes, the ground is normally de-rated to a smaller size
No, that is very dangerous.
I think you should stop playing electrician
Anti-wingnut is offline   Reply With Quote
Old 10-21-2009, 10:45 AM   #19
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
dpride, you need to read a book or two before you try and do this.
The questions you are asking indicated that you do not have the basic iodea on electrical work.
Read a couple of books, then come back and ask the questions, or hire someone to do this.
Old 10-21-2009, 11:17 AM   #20
I'd also recommend reading up, do a search on this forum for sub-panels & read & make notes
Pick up a book & read thru that
From sub to ground rods is #6 min as I understand
The breaker you have is a 30a 240v breaker
That will give you 30a 240v in the sub
It gives you 30a 120v on each hot leg
You can't us a 30a 240v 2 pole breaker to supply 60a 240v...that really should be obvious
You also can't use (2) single breakers to supply a 240v sub
You need to read, research & fully understand this before attempting it
Old 10-21-2009, 11:46 AM   #21
Rewards Points: 1,514
Using 10 gauge wire from house to your shed subpanel you can use your double 30 amp breaker (handles joined together) at your house panel to provide 30 amps at 240 volts some or all of which can be taken instead as two groups of up to 30 amps each at 120 volts.
Using 8 gauge wire you can do the same and upgrade later, or upgrade now to 40 amps at 240 volts.
If you don't want to install the subpanel yet, you can still string the 10 or 8 or even 6 gauge wires for future upgrading but at your house panel you are restricted to a 20 amp (also dual) breaker when installing regular lights, receptacles, and switches in your shed.
Old 10-21-2009, 11:53 AM   #22
47_47's Avatar
Rewards Points: 58
Well stated
47_47 is online now   Reply With Quote
Old 10-21-2009, 12:21 PM   #23
Thumbs up
Issue of protecting 15 & 20 Amp. outlets w. 30 Amp. breaker!
Scuba Dave, I'm in California, the outlets will be 15a, the breakers will be 30 amps due to multiple items running at a couple amps each. I'm running a few amplifiers and speakers, I've already done the math on it and know it'll be fine with what I'm looking for. It'll be 120v, I've also started the trench myself, saving a few bucks but damn am i tired. I'll keep an eye out for the grounding rods, thanks.
JV thanks for the heads up, I now see what you're talking about, I will gather up anything I can't find and let you know, so far so good though.
Thanks again.
As Scuba Dave pointed out. You can't run 15a. or 20a. outlets on a 30 Amp, breaker. It has to match wire size. Additionally. They don't come in single pole. (Obviously for the same reason. They're made for compressors and other motors that run on 240V. or 208V.)! (No matter what) Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 10-21-2009, 06:30 PM   #24
Dont worry everybody, i might be ig, but im not stupid. i have not started doing anything yet and just simply wanted to get all the needed parts and then have a skilled electrician come out.
All said, im screwed... i just went and looked and my main panel is an FPE stab Lok. This whole project just went to $H!T.
thank you all (who werent talking crap) for your help.
Tags
electrical , music , studio , sub panel
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Panel Replacement/Upgrade 400 Amp AndrewF Electrical 42 01-07-2009 10:47 PM
New meter panel tomreva Electrical 3 01-08-2008 03:56 PM
