Need To Install A Sub Panel! - Electrical - DIY Chatroom Home Improvement Forum
Old 10-09-2009, 10:09 AM   #1
Exclamation
Need to Install a Sub panel!
Hi,
i bought my first home about 6 months ago and it just happened to have a 10' x 20' "shed" (more like a small studio, carpet and everything) in the backyard. the power had been removed completely before the purchase because it wasn't permitted. Now to the fun part, I want to run a sub panel in the shed and turn this room into a small music rehearsal studio. i just want 4, 30 amp breakers, 1 will be for lighting, 1 for an AC unit, the other 2 will have 6 outlets on each. The location of the shed is about 75 feet away from the main panel which is outside of the garage, so fortunate, on the opposite end of the property. What advice can someone give me to make sure I don't burn the house down or the shed?
I came up on some wire, 10 GA white and black, and 14 green. will this work?
Will the distance from the main to the sub require that i use aluminum?
Any advice i can get on this will be great!
Thanks.
dPride is offline   Reply With Quote
Old 10-09-2009, 10:23 AM   #2
Where are you located?
In the US branch circuits are 15a & 20a
What size AC, what power requirements ?
Are you going to bury this run?
You need it 18" deep for grey PVC conduit
You alse need grounding rods at the detached shed
Old 10-09-2009, 11:22 AM   #3
Rewards Points: 156
This the most often asked question on this forum by far "how to install a sub panel". Above, see the search function and search "sub panels", "unattached structures" "Wire to shed" those types of keywords. You will be able to get everything and more this way. You will be an expert in no time. If you have any further questions, just let us know.
If it worked before you worked on it. You did something wrong.
Old 10-09-2009, 11:38 AM   #4
Scuba Dave, I'm in California, the outlets will be 15a, the breakers will be 30 amps due to multiple items running at a couple amps each. I'm running a few amplifiers and speakers, I've already done the math on it and know it'll be fine with what I'm looking for. It'll be 120v, I've also started the trench myself, saving a few bucks but damn am i tired. I'll keep an eye out for the grounding rods, thanks.
JV thanks for the heads up, I now see what you're talking about, I will gather up anything I can't find and let you know, so far so good though.
Thanks again.
Old 10-09-2009, 11:44 AM   #5
You can't install a 30a breaker & a 15a or a 20a outlet
Doesn't meet code & is not safe
Old 10-09-2009, 11:47 AM   #6
I'm running 6, 15a outlets on 1 30a breaker.
Old 10-09-2009, 11:48 AM   #7
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
There's very little reason to have more then 20.
If you have equipment that needs 30 it will probably have a specialized plug or need to be wired directly.
Old 10-09-2009, 11:50 AM   #8
It does not work that way
You would need outlets capable of handling 30a
These are special outlets that take a special plug
You need 20a breaker, 12g wire & either 20a outlets OR 15a outlets that are rated for 20a pass thru
You can't do a 30a breaker with 15a outlets PERIOD
Old 10-09-2009, 11:53 AM   #9
So if i have 12 pieces of equipment that each use 2amps, that would be 24 total, that's not how its calculated?
Old 10-09-2009, 12:03 PM   #10
No
You start with your load...24a
That means you need (2) circuits - not one
Normal household branch circuits are either 15a or 20a
Special circuits can be more - I have a 24,000BTU AC that needs 10g wire, 30a 240v breaker & a special 30a outlet
So you need to split this into (2) circuits IF you expect this all to be running at the same time
I usually only run 20a circuits for outlets, 12g wire
You balance the loads across the circuits
You don't add them up to see what size breaker you need
Once you have the loads you then decide on breaker & wire
12g is good for up to 20a load = 2400 watts
14g is good for up to 15a load = 1800 watts
Usually do lights - 14g & 15a breaker
But if you are going to buy a roll of wire it might be cheaper to just buy all 12g
The total Load +spare power = less then the main breaker for the sub panel
Old 10-09-2009, 12:04 PM   #11
Civil Engineer
Rewards Points: 4,762
Outlets are typically daisy chained, meaning the power to first outlet in the chain feeds the second outlet off of load screws on the first outlet. Similarly, the second outlet feeds the third, and so on down the line.
In your case, if each outlet of the 12 had 2A on it, you would indeed draw a total of 24A, and that would be the load on the wire to the first outlet. The problem is that you need to protect the wire to the outlets, so if you use #12 wire (typical), the wire is rated for a maximum of 20A, so you would protect the wire with a 20A breaker. So when you hit the 20A maximum on the circuit, you would blow the breaker.
If you used #10 wire to your outlets, you could indeed carry 30A, and you could install a 30A breaker in the panel. However, you would need to use special 30A outlets with a different type of plug than normal, and none of your amplifiers would plug in.
So the solution is to wire standard 20A outlets, limiting the number of outlets on a single 20A breaker to keep the total load below 20A. Meaning if you expect to pull say 2A per outlet, limit each run to perhaps 6 outlets per breaker, and add a second breaker for another run of 6 outlets. This way you use standard outlets, 12 gage wire, and one 20A breaker per run.
Old 10-09-2009, 01:07 PM   #12
Wow, thank you guys for your help, i know an "electrician" whos losing a job now.good thing i havent bought everything yet.
Again, thank you!
Old 10-09-2009, 01:10 PM   #13
Just check your amps & everything
Make sure they don't have a special plug that needs a 30a outlet
In that case you would need 10g wire & a 30a rated outlet
Old 10-09-2009, 01:40 PM   #14
As you offered, you should just go ahead and burn your house down and save the labor and expense.....
Little friday humor. good advice about searching panel installation code. Cant run outlets by code over 20 amps and thus 12 ga wire. Otherwise you will burn the shed down
fisherman2001 is offline   Reply With Quote
Old 10-09-2009, 03:52 PM   #15
I got a new question, for the 2 breakers that im going to run for the outlets, can i run them through one conduit?
Also, since one outlet actually has two sockets, it would be 4amps per outlet, so i should run 5 outlets on each breaker, or could i run 6 outlets per 20amp breaker? itd be nice to have a couple extra outlets to charge my phone or something.
Tags
electrical , music , studio , sub panel
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Panel Replacement/Upgrade 400 Amp AndrewF Electrical 42 01-07-2009 10:47 PM
New meter panel tomreva Electrical 3 01-08-2008 03:56 PM
