Need Help With Woodshop Subpanel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-02-2011, 10:23 AM   #16
Licensed electrician
Rewards Points: 1,612
Only if the entire run is sized with #10 could you upgrade to a 30 amp breaker to feed the subpanel.
pdoubleu (11-03-2011)
Old 11-02-2011, 10:29 AM   #17
Ok. So ill replace the small length of 12/3 with 10/3. That will make the entire run 10/3 to the box in the shop. Then change the 20 amp double pole in main panel,with 30 amp double pole correct?
pdoubleu is offline   Reply With Quote
Old 11-02-2011, 07:52 PM   #18
Nada?
Several Questions...leading to Garage Subpanel willstutely Electrical 5 01-03-2012 01:38 PM
Wiring Subpanel off Subpanel brgmgb Electrical 2 08-29-2011 04:18 PM
Grounding a Subpanel Craigman Electrical 25 12-07-2009 07:25 PM
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 08:44 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
