Need Help With Wiring Please??? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2010, 05:26 PM   #1
Need help with wiring please???
Hello,
I am hoping someone can help me out here. I am trying to wire a small space heater with fan that has been dissassembled for a project I am working on. I would like to have the heating element on a dimmer so it does not run to hot. I know the two small black wires are for the fan and those will be wired separatly as I want it to always be on. Is this even possible to put a dimmer on this application? Any help and suggestions is much appreciated. Thanks in advance!
chef1 is offline   Reply With Quote
Old 11-02-2010, 05:29 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
DO NOT try to modifiy the heater.
It will not work with a dimmer between the elements.
This is a fire waiting to happen!
jbfan is online now   Reply With Quote
Old 11-02-2010, 05:59 PM   #3
Thanks for the response. I'm definetly not looking for a fire! What if I didnt use the dimmer? I am building a large incubator and would like to use this heater as the heating element. Can I wire it to just turn on the element? It will be put on a digital temp controller to shut it on and off.
Old 11-02-2010, 06:10 PM   #4
kbsparky's Avatar
I would use heat lamps, which can be safely used with dimmers. Much cheaper and easier to wire up as well ....
-KB
Old 11-02-2010, 06:20 PM   #5
Thanks for the suggestion. I think I am going to go with the heat lamp and use the fan only.
Chef
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
