Need Help Wiring Old 220v Fan Motor - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-15-2009, 05:51 PM   #16
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Originally Posted by ctsmiths View Post
From what I can see I belive you need to wire the brown & black together and to one side of the 240, the white & blue together, and then only the red to the other side of the 240. You also need a 2 pole single throw motor switch for this so it only comes on with 240 and breaks both lines when off. Again this is only going by the print you have posted and its hard to read no guarantees.
This will not be liked by the motor.....
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-15-2009, 06:35 PM   #17
Originally Posted by Stubbie View Post
Ok I thought you understood but I guess I misunderstood that you did.The wiring diagram is for 240 volt motor.
Black = High Speed
Blue = Meduim speed (cap this wire off it is unused)
Yellow = Medium low (cap this wire off it is unused)
Red = Medium (cap this wire off it is unused
Connect the black (high speed) to one hot wire
There is a white wire coming from the motor it is common and goes to the main run winding. At the capacitor this wire is connected on a spade with another wire this other wire is your other hot wire.
On the other side of the capacitor is the brown it goes to the motor start winding.
For a 240 motor the windings are in series not parallel. Parallel is for 120 volt motors.
A centrifugal switch in the brown wire (inside the motor)will take that series circuit out when it opens after the motor gets up to a certain rpm then the white coming from the motor connected to the capacitor with the other hot wire becomes your series run circuit at high speed....clear??
You keep mentioning 220 and 120 and neutrals so what does the motor nameplate say??
Furnace blower motors are one or the other.. most are 120 volt but there are 230 volt models also. It would be extremely uncommon for the motor to be dual voltage rated for a furnace application.
Maybe you could post a diagram of how you wired it and we can give you the corrections.
If you connect all those other speed wires in any way you will burn your motor up and it will be toast. When you install the furnace it is usually wired medium. If you want to change speed you disconnect the medium speed from the hot and reconnect to the speed wire you want as identified on the diagram. It really is easy to see it on the diagram. You never change the wiring at the capacitor.
Thanks for your patience. My shop wiring has a four wire setup. I understand them to be two hots, one neutral and one ground. I understand how to attach the two hot wires (L1 and L2) per your instructions. I assume the neutral is not used and the ground is attached to the motor/fan housing. I'll try it tomorrow and report back.
The nameplate on my motor allows me to read everything but the voltage. That is covered by a support bracket that is riveted to the motor. The furnace system it was taken from is clearly labeled as a 240 volt system. The system is also labeled as a Bryant model 320-960D. The system is so old that I have found no reference to it on the Internet.
The good news is that I have about ten more of these old fans to play with, so it's no great loss if I cook one along the way.
HotTommy is offline   Reply With Quote
Old 02-15-2009, 06:50 PM   #18
UAW SKILLED TRADES
Stubbie's Avatar
Ok...the diagram is very hard to read so just to make sure I am correct look on your diagram and tell me the colors that are connected to the capacitor. I know one is brown I'm reading the other as white...is that correct?
Black is a no brainer but it is possible that I have the white wrong.
Stubbie
Old 02-15-2009, 07:28 PM   #19
There are six wires coming from the motor. The colors are red, black, white, blue, yellow and brown. The two wires from motor to the capacitor are colors white and brown.
Old 02-15-2009, 07:40 PM   #20
UAW SKILLED TRADES
Stubbie's Avatar
Ok how did your wiring differ from this if it did??
Stubbie
Old 02-15-2009, 08:10 PM   #21
Make ohmmeter measurements before you apply power so you can tell if it's cooked later or just not running for other reasons.
With six wires plus the motor shell this is 6+5+4+3+2+1 measurements.
Old 02-15-2009, 08:14 PM   #22
Electrician
ctsmiths's Avatar
Rewards Points: 150
Well, like I said no guarantees its really hard to see the print and I couldnt tell if wires were jumping or connecting together at the cross points. I see what you re saying about high ,med ,low, couldnt really read the top at all. I havent run into too many 220v single phase, mostly three phase high voltage and 110v single phase, but I do mostly indrustrial.
But I still think that he should be using a double pole single throw or the motor will be energized if its 220 and the switch, plus the arc from starting is too much for a regular switch, he needs a switch designed for motors.
Switching
Low Voltage (110) Use a "Single Pole/Single Throw" switch since only the black wire needs to be switched.
High Voltage (220) Use a "Double Pole/Single Throw" since both the black and white wires need to be switched.
This configuration may also be used on a Low Voltage machine if there is a possibility it will be changed to High Voltage later on.
ctsmiths is offline   Reply With Quote
Old 02-15-2009, 08:21 PM   #23
The drawing below is how I wired the motor for the test I described in an earlier post. Based on your subsequent post, I should have connected the second Hot lead (L2) to the capacitor post where the white wire from the motor is connected. And I should not have the neutral shop wire connected to any of the motor or capacitor wiring.
BTW, I have been trying without success to figure out how to upload photo directly to his site. In the mean time, I'm uploading photos to Flickr and it insists on shrinking them to eye straining sizes. I'm trying to make it easier for you, but I haven't figured out how yet.
Old 02-15-2009, 08:29 PM   #24
UAW SKILLED TRADES
Stubbie's Avatar
Switching
No problem... just pointing it out and yes the diagram is hard to read. Most fan motors have independent leads for both L1 and L2. The most common for 230 volt for high speed is a connection to a yellow and black. With a brown and brown/white stripe going to the capacitor. But this diagram he is showing shows all leads but white and brown as speed leads. I can't tell where the one that comes off the capacitor goes to and we still don't know for sure this motor of his is 240 volt. I'm not sure how he is determining it and he keeps talking 120 and 240 he needs to get the name plate voltage some how some way. So I don't know if he is trying both voltages on the motor or what??
Code only requires one pole to be broken on a 230 volt single phase motor disconnect. 2 pole is fine. This motor is fractional hp so any 15 or 20 amp switch will work
Stubbie
Old 02-15-2009, 08:41 PM   #25
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
If you're talking about the white capacitor wire it goes to the fuse block and then to the "electric control box"
wirenut1110 is offline   Reply With Quote
Old 02-15-2009, 08:48 PM   #26
Rewards Points: 510
See if you can see this better
Old 02-15-2009, 08:50 PM   #27
OK, here's the longer version of what happened on my first test. I didn't invest in a SPDT switch yet because I didn't know if this nearly 40 year old motor and fan assembly would work until I tested it. So, I shut off the two circuit breakers to the 240 volt circuit, wired the motor directly to it and turned the CBs back on. The motor started to run at a low speed. When I went to turn the CBs off, one CB clicked off before the other and the fan immediately went to a much higher speed. Clearly, since only once circuit was hot, it was running on 110 volts and not 240. Being curious, I tried other combinations of CBs off and on and reported them in my earlier posts. I have no reason to believe the motor was intended to run on 110. I was just curious as to why it ran faster on 110 than on 240. Apparently it was because it was wired wrong at that time.
Old 02-15-2009, 08:57 PM   #28
Rewards Points: 510
How are these breakers situated in the panel? Top/bottom side by side?
Old 02-15-2009, 09:15 PM   #29
UAW SKILLED TRADES
Stubbie's Avatar
Wirenuts diagram is much easier to see. Your tests confirm that it ran on 120 volts becaue you had the neutral connected to the capacitor. When the hot connected to the brown dropped out when the breaker tripped the motor only saw 120 volts and sped up cause you had a good circuit.
If you connect as I drew the diagram and forget that neutral and this is a 240 volt motor I'm pretty certain it will run fine. However if this is a 120 volt motor and you see a lot of sparks flying and maybe smoke then it will be too late...just a warning.
EDIT: Just so you understand 240 volts does not use a neutral.
Stubbie
Blower Motor Wiring Help atvguy64 Electrical 11 08-14-2015 09:02 PM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 05:13 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Pool Motor Wiring Assistance tazmajazz Electrical 18 05-16-2008 10:42 PM
Blower motor wiring help!! atvguy64 HVAC 4 02-04-2008 08:27 PM
