Old 03-29-2011, 03:31 PM   #1
Need Help Wiring New Celing Fan Switch
Hi all,
This is my first topic on DIY Forums. My wife and I just purchased a new house and we want to replace the simple one flip switch (fan and light control) with a switch that can control fan and lighting separately.
I'm not sure how to connect the wires since they are not the same colors.
I've attached pics for reference.
Thanks!
Jason
Outlet Wiring
New Fan Switch
stradt03 is offline   Reply With Quote
Old 03-29-2011, 03:34 PM   #2
Electrical Contractor
You need another wire from the switch to the fan for seperate controls.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 03-29-2011, 04:02 PM   #3
crap....That probably isn't an easy thing to do is it?
Old 03-29-2011, 06:04 PM   #4
kbsparky's Avatar
Actually, a simple solution exists for your problem. You just have to think outside the box.
Instead of using a wall control only, consider using a wall-mounted remote unit. IT allows for one to use an existing 2-wire cable, and splits up the signal into separate fan/light wires at the fan unit itself.
The receiver mounts inside of the fan canopy, and a similar looking wall control replaces your wall switch. An optional wireless remote control unit may also be supplied.
-KB
Fitting dimmer switch to old electrical wiring hugomax69 Electrical 0 01-29-2010 08:40 PM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
4 way switch wiring ponch37300 Electrical 9 02-16-2009 10:58 AM
problem with wiring...celing fan/switch anywhofaq Electrical 8 05-09-2008 05:20 PM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 08:47 PM
