Need Help Wiring A/C.... - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2008, 05:17 PM   #1
Need help wiring A/C....
I need help on hooking up my 220 volt air handler with heat strip. The A/C guys came and installed it, but I want to wire it. I'm a little confused with it though and the reason is that there are two wires...one is yellow, the other is black that aren't hooked to anything just hanging there.
I can see where the 220 wires go, but not sure what to do with these other two. I took some pictures and hope that they are good enough for you guys. Let me know if you need better pictures.
Also, I understand that I have to have a disconnect near this air handler. So I bought one at Lowe's. However, the front of the panel on the air handler has two slots that are just like the rectangle slots on a circuit breaker panel. Do I just knock one out and run the wires through that??
Any help is appreciated. Thank you.
Need help wiring A/C....-electric11.jpg   Need help wiring A/C....-electric-001.jpg   Need help wiring A/C....-electric-003.jpg
737Pilot is offline   Reply With Quote
Old 12-17-2008, 05:23 PM   #2
Electrician
What does the wiring diagram say? You may just want to call someone.
chris75 is offline   Reply With Quote
Old 12-17-2008, 05:49 PM   #3
The unit should have a round knock out in one of the sides. Do not run the wiring thru the acces panel. You may have to drill a hole for the wiring.
I can't see where the yelow/black go to. I am thinking they go to the blower. Post a pic of the wiring diagram that is probably on the access panel.
220/221 is offline   Reply With Quote
Old 12-17-2008, 06:09 PM   #4
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
I would just post this in the HVAC forum.
wirenut1110 is offline   Reply With Quote
Old 12-17-2008, 07:21 PM   #5
Idiot Emeritus
Rewards Points: 1,492
If the two plugs were plugged together, it looks a lot like the yellow and black would be a constant hot 240 volts. Very likely some sort of accessory that may or may not be installed in your unit.
If it were me, I'd first look at the wiring diagram, and if I couldn't find anything, I'd hook the unit up to power leaving the plug unplugged (like it is now), and see if it works. If so, then nothing hooks up to these wires. If not, you'll need to look a bit deeper.
Rob
micromind is offline   Reply With Quote
Old 12-17-2008, 08:45 PM   #6
Thanks for the replies, I'll post the wiring diagram tomorrow.
Old 12-17-2008, 09:29 PM   #7
Sometimes things like this have instructions for the customer and have separate "Installation Instructions". I would read the installation instructions and look at the wiring diagram.
Billy_Bob is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Electrical problem, bad wiring? mumblemouth Electrical 10 08-09-2008 11:52 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
