Need Help Wiring - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-07-2013, 05:36 PM   #31
Rewards Points: 2,516
Originally Posted by jhack836 View Post
so basically the only way to do what I want to do is to add a 3rd wire to the outlet? correct?
I have no idea what your current setup is like. But the diagrams I have shown will function as you want. With one part of the receptacle always HOT and the other part of the receptacle controlled by a switch.
Apply the principle of the drawings to your situation.
hammerlane is offline   Reply With Quote
Old 06-07-2013, 05:42 PM   #32
Rewards Points: 160
so one of those to the attic is probably the incoming power. the other side of the box is 1 outlet
jhack836 is offline   Reply With Quote
Old 06-07-2013, 06:26 PM   #33
MarginallyQualified
Rewards Points: 2,464
The only way to do what you want to do requires a TWO more wires there: the actual feed for the receptacle circuit that the switch loop pair would tie into.
1) B/W (120V) ---> receptacle
2) feed black to TOP brass screw
3) tie into that feed black wire (pigtail, backstab, etc)
4) run that wire up to to/through the switch
5) run it's pair back down to the BOTTOM screw on the receptacle
It doesn't appear that you have the 120V feed to the receptacle box.
Old 06-07-2013, 07:09 PM   #34
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,796
Say Jhack... Curiosity that your wired in BX (AC)... Where ya from... is this Chicago area?????
Best
Peter
MTN REMODEL LLC is offline   Reply With Quote
Old 06-07-2013, 07:23 PM   #35
Dont you know how to determine which pair of wires is your feed? If not back to high school electrical shop.
Old 06-07-2013, 07:48 PM   #36
Rewards Points: 512
Need to run a 14/2 (or 12/2, whatever the branch size is) from the jbox to the receptacle.
I'm visualizing that the white wire in this run would have no connection. He just needs to pick up the hot in the jbox, and switch loop there, right?
Hammerlane, I can't upload any of my pics. If I'm correct, and you understand what I'm saying, maybe you can draw it?
Installation is the Reverse of Removal.
Old 06-07-2013, 07:52 PM   #37
Sir Sparky.... He's in AC... see his new picture above... don't know/see distances, but kinda looks like an easy pull...?
Old 06-07-2013, 08:18 PM   #38
Rewards Points: 160
from se wisconsin
Old 06-07-2013, 09:09 PM   #39
Rewards Points: 512
Here's a diagram that should work, should you be able to find the hot wire in the jbox.
Old 06-08-2013, 05:44 AM   #40
Bill Kearney
Rewards Points: 1,174
You can GET to the back side like that? Well, hell, that makes the job a shedload easier. Yeah, you'd need a 14/3 (or 12/3) pulled to the outlet. Replace the existing 2-conductor line.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
Gac66610 (06-08-2013)
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
