Need Help, What Is This Steel Bracket For? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2008, 03:58 PM   #1
Need help, what is this steel bracket for?
I found this metal bracket between attached between the studs in my kitchen wall and have no idea what it is, Its a 1940s home. Any ideas? Thanks in advace.
gchaim is offline   Reply With Quote
Old 11-01-2008, 04:10 PM   #2
dSilanskas's Avatar
That bracket was used to hold a box. Most likely an old octagon box. If you see there is a place for a screw in the center of the part that moves back and fourth that attached to the center of a box it held
dSilanskas is offline   Reply With Quote
Old 11-01-2008, 04:29 PM   #3
thanks, that makes sense. Do you see any reason why I shouldn't remove it? It would make the drywall sit more flush if it wasn't there.
Old 11-01-2008, 04:37 PM   #4
dSilanskas's Avatar
Take it out. The box is no longer there so no need for it
Need help, what is this steel bracket for? gchaim Remodeling 5 03-18-2009 01:25 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
steel stud questions drewhart Carpentry 4 08-20-2008 09:39 PM
Painting Steel I-beams For Outside Retaining Wall lyndon9 Painting 3 07-05-2008 11:55 PM
