Need Help What Is This? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-17-2012, 02:43 PM   #1
Need help what is this?
I just moved into a older house and i have a light switch that doesn't work its not getting power while talking out some of the wall i found this little thing here is the whole wiring Thanks
liljoey112 is offline   Reply With Quote
Old 11-17-2012, 02:54 PM   #2
What 'little thing' are you referring to?
VIPlumber is offline   Reply With Quote
Old 11-17-2012, 02:56 PM   #3
http://s1278.beta.photobucket.com/us...tml?sort=3&o=1 that I dont no what it is
Old 11-17-2012, 03:04 PM   #4
Pure Genius
Rewards Points: 150
Thats the knob of knob and tube wiring.
Dierte is offline   Reply With Quote
Old 11-17-2012, 03:06 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Call a pro! Now that you have exposed it,replace it with new wire.
sublime2 is offline   Reply With Quote
Old 11-17-2012, 03:09 PM   #6
Yes but what is that ceramic looking thing
Old 11-17-2012, 04:03 PM   #7
Rewards Points: 14,300
It's an insulater.
Old 11-17-2012, 04:30 PM   #8
what is it for/do? I am new to this
Old 11-17-2012, 04:34 PM   #9
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
It's what your house wire is attached to,running through.
Look at it as a junction box before there were junction boxes.
Old 11-17-2012, 04:34 PM   #10
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There is nothing that mandates removal of knob and tube. While "replacing it with new wire" sounds easy enough, that could feed 1/2 the house.
Old 11-17-2012, 04:37 PM   #11
k_buz's Avatar
It isn't anything like a junction box. Its like a romex staple. They wrap the wire around those and it clamps down to hold the wire tight/in place. In fact, with knob and tube, they didn't use any sort of junction box. The splices were done and buried in the wall.
The Following User Says Thank You to k_buz For This Useful Post:
liljoey112 (11-17-2012)
Old 11-17-2012, 04:42 PM   #12
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Never implied or stated there was a mandate.
Weather it feeds half the house or not,if it can be replaced with new wire,do so.
Old 11-17-2012, 04:48 PM   #13
k_buz's Avatar
He doesn't even know what it is and you want him to go ahead and replace it. Replacing knob and tube is not an easy job for professionals and it could turn into a nightmare for homeowners who don't know anything about how knob and tube as commonly run.
brric (11-17-2012)
Old 11-17-2012, 04:54 PM   #14
So its basically like a cap you use to cover wires when you twist them up?
Old 11-17-2012, 04:56 PM   #15
k_buz's Avatar
Reread post #11.
