-   -   Need HELP w/ wiring project (http://www.diychatroom.com/f18/need-help-w-wiring-project-26690/)
scopus1972 09-11-2008 09:30 PM
1 Attachment(s)
I've recently install 4 IC recessed lights in our attic. And ran a wire down to an existing light switch. The light switch was previously wired to the top plug of an outlet (we had to plug a lamp into the outlet for the switch to control it).
So, I've wired everything up using 14/2 bx wire. I've also purchased a dual dimmer switch, I've broken the room down into two lighting sections, the bottom dimmer switch is to control lights #1 & 2, while the top dimmer is to control lights #3 & 4.
The problem is, it doesn't work. :no:
Not sure exactly what I've done wrong but I'm including a diagram hoping someone might point me in the right direction.
And just as a side note, I tried the existing wiring with a regular light switch as well (just hooked up to lights 1 & 2) to eliminate the possibility that the dimmer switch is bad. I also replaced the light bulbs to ensure that wasn't the problem.
Really appreciate anyone's advice!
HouseHelper 09-11-2008 09:50 PM
You don't have a neutral going to the lights, and you need 14/3 between the dimmers and the junction box.
The white from the receptacle should be joined to the white from the 14/3 at the dimmer and continue to the junction box where it is attached to the whites from the lights.
The black from the receptacle would connect to the hot in screw of the dimmers. The red and black of the 14/3 would connect to the switched screws of the dimmer. At the junction box, the red and black would connect to the switched hot wires of each light string.
scopus1972 09-11-2008 10:06 PM
Thanks for the quick response and help, really appreciate it.
Termite 09-11-2008 11:28 PM
Might be an interpretive issue on my part, but it appears in the drawing that the neutral and the phase (black) are hooked together in the junction box. That isn't good.
handyman78 09-12-2008 07:50 AM
No you are correct- it looks pretty clear in that drawing that the connection from switches to junction are missing a hot conductor-
The white whire was used where it shouldn't-:no:
All neutrals are to connect together from the supply thru to the lights, just like the ground does.
