Need Help W/ Portable Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2009, 05:05 PM   #1
Need help w/ portable generator
Just picked up today and was told it worked. Engine ran great but no juice....my fault not to test but either case it was a super low price.
It's a Coleman Powermate 5000 with the Subaru engine or whoever makes it. No juice at recepticles, pulled black plug from behind, only 2-4 volts at white and black....two whites, two blacks 1 ground.
Where do I need to look to make it work?
Brushes, relays, whatever, I can put $200 and still be way ahead.
Upsets me but hopefully I can make it right.
i6pwr is offline   Reply With Quote
Old 01-18-2009, 05:26 PM   #2
joed's Avatar
Rewards Points: 12,332
start by googling "generator flashing" the field could have lost its magnetism.\
Here is one of the simplest ways to do it if it works.
http://www.perr.com/tip16.html
It doesn't say in the article but I would use a cordless drill to spin the corded drill.
Old 01-18-2009, 05:26 PM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Have you checked voltage at the circuit breaker(s)?
wirenut1110 is offline   Reply With Quote
Old 01-18-2009, 05:40 PM   #4
Rewards Points: 510
This site may help you. It has exploded views of the generator. You can start and work your back.
http://www.powermate.com/productmanuals.php?cat_id=3
Forgot to mention Go Cardinals, Go Ravens!!!!!!
Old 01-18-2009, 05:47 PM   #5
Are there breakers before the wires leave the generator, I will check the parts diagram.
Old 01-18-2009, 05:49 PM   #6
Electrician
Sometimes they just have resettable push in breakers.
chris75 is offline   Reply With Quote
Old 01-18-2009, 05:57 PM   #7
The two push-in breakers on the front panel are pushed in as far as I can tell. I pulled the main harness from the rear of the panel that comes directly from the generator itself. Only 2-4 VAC, tried alll the wires even the ground.
Would love to call the guy back and tell him he didn't get the best of me.
Old 01-18-2009, 06:24 PM   #8
Idiot Emeritus
Rewards Points: 1,492
Almost certainly the field has lost its residual magnetism. If the generator end has been taken off, this is certain. You'll need to 'flash' the field. The link that joed provided works a good part of the time. If not, there are other methods.
Rob
micromind is offline   Reply With Quote
Old 01-18-2009, 06:34 PM   #9
I'll get the kids off to bed and take some pics so we can see what we are dealing with. I read that link and is very informative...at least it makes me feel better that I can possibly salvage this thing.
Then we can take some readings and see what we have. I'm all about tearing things down to see how they work and how to fix them
Old 01-18-2009, 08:21 PM   #10
Here she is......
So where do we start
Old 01-18-2009, 08:32 PM   #11
Forgot to mention it's not a good time to fire it up and flash the magnets, I figure I can check out the guts under the cover to possibly eliminate any other probs.
Then in the A.M. I will try to flash the magnets.
Old 01-19-2009, 10:45 AM   #12
joed's Avatar
Check the brush that rubs on the outer ring. That ring should be nice and polished lke the inner one. Outer brush looks like it is not making full contact.
Old 01-19-2009, 11:03 AM   #13
Rewards Points: 126
Thats why you got it so cheap, it's broke. Take it to a small engine shop that reps your brand.
Old 01-19-2009, 01:07 PM   #14
I found a good article on these things....
http://www.fixya.com/support/t132926...pm0555523_only
Spent about an hour with it last night and put it back together this morning, along with what joed said, the slip rings needed a little shine.
Took a 3M pad to the rings and it works like a champ, didn't even need to flash the mags.
Thanks for all the tips, I figured it was too good to be true but I will have the last laugh, he avoided all my calls last night to boot.
The 10 HP Subaru motor really runs quiet, not like a newer Honda but much quieter than I expected.
240v Welder powered by portable generator? MRJChannahon Electrical 19 03-30-2009 05:19 PM
Trickle charger on portable generator - bad battery? timp Electrical 5 01-01-2009 07:46 PM
240v Welder powered by portable generator jackgerd Electrical 10 11-06-2008 01:38 PM
Better way to protect portable generator inlet? IvoryRing Electrical 7 05-30-2006 07:30 PM
