Need Help W/ LED Deck Lights. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 08:00 AM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Need help w/ LED deck lights.
There is a small floodlight which will be providing light for the deck itself. I might go more creative later, but not sure.
The stairs (4 steps) will have 2 recessed LED's (one in each side) each.
So that's 8 LED's and one 12V transformer.
The power source is in the garage (about 10-12 feet away)
What I'm not sure of is which wire to make "long".
In other words, should I have the low voltage wire be the short one and have the transformer located close to the stairs and the 120V wire going to the garage from there.
Or...
Have the low voltage wire run from the LED's to the garage and into the transformer which would then have a short 12V run to the power source?
Sorry if this is a simple question - my brain freezes sometimes w/ electrical stuff.
CoconutPete is offline   Reply With Quote
Old 06-05-2011, 09:08 PM   #2
AfterDinnerDIY.com
I would have the long wire be the low voltage.
It all depends on the wire though. Normal voltage wire needs to be in a conduit or run through a wall (ie protected), where most low voltage can be buried without conduit.
Why LED's ?
The cost is way more than standard low voltage. Actually the cost is so much more, you dont have a good chance of recouping the cost.
AfterDinner is offline   Reply With Quote
Old 06-06-2011, 09:05 AM   #3
Rewards Points: 504
I was thinking the same thing - much easier to bury the low voltage wire. I thnk that's what I'm going to do.
I agree that the cost is so much more if you buy one of those ridiculously ripoff priced "kits" you see all over. If you go to a marine supply store and buy the recessed waterproof ones for $3.93 a pop you end up with a much better number
Deck stain project gone bad - HELP brownnl Painting 13 03-15-2011 01:57 PM
Re-attaching Deck to Ledger Board B-Web Building & Construction 5 12-13-2010 08:05 AM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 10:15 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
