Need Help Understanding GFCI & AFCI - Electrical - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 08:24 AM   #1
Rewards Points: 150
Need help understanding GFCI & AFCI
I learned a little about GFCI & AFCI yesterday at the Home Depot. The electrical guy explained it like this:
GFCI protects humans against being shocked.
GFCI are required in any room with water or a bare concrete floor (local code)
GFCI can be a breaker or receptacle. If installed as receptacles -- one GFCI receptacle at the beginning of the circuit will protect non-GFCI receptacles further down the circuit.
AFCI protects houses against fire
AFCI are required in bedrooms, dining rooms, living rooms, ect where there is no water
AFCI are breakers and protect the entire circuit
I may be misstating what he said but that is how I remembered it.
He said something else that confused me - AFCI breakers cannot be used on the same circuit as GFCI receptacles. Then he said that maybe you could but it might not pass code.
Why can't GFCI receptacles be used on AFCI protected circuits?
Why would this be against code?
sheslostcontrol is offline   Reply With Quote
Old 10-30-2010, 08:39 AM   #2
Master Electrician
Rewards Points: 3,760
GFCI receps will work fine on AFCI protected circuits.
brric is offline   Reply With Quote
Old 10-30-2010, 09:11 AM   #3
Rewards Points: 150
Is there a reason a circuit with AFCI & GFCI would not meet code and fail inspection?
Old 10-30-2010, 09:39 AM   #4
Licensed electrician
Rewards Points: 1,266
Going above what the code requires is fine.
Old 10-30-2010, 10:08 AM   #5
Graduate of Wiring 1-2-3
You need both if there is an aquarium in the bedroom.
Lurlene is offline   Reply With Quote
Old 10-30-2010, 10:22 AM   #6
Master Electrician
Where could I find this in the NEC?
Old 10-31-2010, 01:24 AM   #7
My preference, maybe not NEC's. I've got both in my bedroom, no problem so far.
Old 10-31-2010, 07:15 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,876
You didn't say that. You said "You need...". This implies it is mandatory, which it is not.
This is why non-professionals should refrain from giving advice on boards like this.
Old 10-31-2010, 08:10 AM   #9
Just call me Andrew
Rewards Points: 1,020
I wonder if anyone will manufacture AFCI/GFCI combination (not a combination-type AFCI) breaker. I mean one that truly does the job of both a standard GFCI breaker and an combination-type AFCI.
I wonder if it would be too big to fit in a standard panel?
Andrew
secutanudu is offline   Reply With Quote
Old 10-31-2010, 09:28 AM   #10
I am waiting for padded walls and floors to become mandatory in a home. Oh, and no sharp edges or corners either.
I really do feel that electricity is just too unsafe to have in a home. There ought to be a law against it.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
jlhaslip (10-31-2010), secutanudu (10-31-2010)
Old 10-31-2010, 06:43 PM   #11
You're right, Pete. I'll stick to asking embarrassing questions and telling amusing stories till I'm a professional.
Old 10-31-2010, 07:18 PM   #12
" Euro " electrician
frenchelectrican's Avatar
I just want to clearify the poster comment about the combation AFCI/GFCI and yes there are few manufacter do make the combo verison I know SqD, ClutterHammer , GE , Seimens and few others do make them and the combo vierson is avibale but the cost will varies a little depending on what brand and which place will stock it.
Merci.
Marc
Old 10-31-2010, 07:32 PM   #13
Master Electrician
The 'combination' feature of arc fault circuit breakers pertains to the fact that they detect both series and parallel arc faults. It has nothing to do with the inherent (50mA or so) ground fault detection of arc fault circuit breakers.
Old 10-31-2010, 07:35 PM   #14
Maybe so but with new combo AFCI/GFCI it will protect personals I will find a link with this set up.
Merci.
Marc
Old 11-01-2010, 12:59 PM   #15
Rewards Points: 3,130
The Home Depot guy's explanation of the two breaker types is pretty much correct. Not so much his code knowledge. I've never heard of using a GFCI on an AFCI circuit (or vice versa) but I don't think it's prohibited.
Were you asking about this for a specific reason? Code requirements vary widely by location. For example, where I live the applicable code is still NEC 2005. In the log house I built I only had to have AFCIs for the bedroom circuits.
GFCI, AFCI, and SABC a7ecorsair Electrical 5 08-20-2010 11:57 PM
Afci & gfci secutanudu Electrical 11 10-13-2009 08:00 AM
code question - AFCI / GFCI breakers Red Squirrel Electrical 15 09-17-2009 12:16 PM
A few questions regarding GFCI AND AFCI protection CowboyAndy Electrical 5 03-10-2008 04:20 PM
