Need help understanding GFCI & AFCI
I learned a little about GFCI & AFCI yesterday at the Home Depot. The electrical guy explained it like this:
GFCI protects humans against being shocked. GFCI are required in any room with water or a bare concrete floor (local code) GFCI can be a breaker or receptacle. If installed as receptacles -- one GFCI receptacle at the beginning of the circuit will protect non-GFCI receptacles further down the circuit. AFCI protects houses against fire AFCI are required in bedrooms, dining rooms, living rooms, ect where there is no water AFCI are breakers and protect the entire circuit I may be misstating what he said but that is how I remembered it. He said something else that confused me - AFCI breakers cannot be used on the same circuit as GFCI receptacles. Then he said that maybe you could but it might not pass code. Why can't GFCI receptacles be used on AFCI protected circuits? Why would this be against code? |
GFCI receps will work fine on AFCI protected circuits.
Is there a reason a circuit with AFCI & GFCI would not meet code and fail inspection?
Going above what the code requires is fine.
You need both if there is an aquarium in the bedroom.
My preference, maybe not NEC's. I've got both in my bedroom, no problem so far.
This is why non-professionals should refrain from giving advice on boards like this. |
I wonder if anyone will manufacture AFCI/GFCI combination (not a combination-type AFCI) breaker. I mean one that truly does the job of both a standard GFCI breaker and an combination-type AFCI.
I wonder if it would be too big to fit in a standard panel? |
I am waiting for padded walls and floors to become mandatory in a home. Oh, and no sharp edges or corners either. :thumbsup:
I really do feel that electricity is just too unsafe to have in a home. There ought to be a law against it. |
Merci. Marc |
The 'combination' feature of arc fault circuit breakers pertains to the fact that they detect both series and parallel arc faults. It has nothing to do with the inherent (50mA or so) ground fault detection of arc fault circuit breakers.
Merci. Marc |
The Home Depot guy's explanation of the two breaker types is pretty much correct. Not so much his code knowledge. I've never heard of using a GFCI on an AFCI circuit (or vice versa) but I don't think it's prohibited.
Were you asking about this for a specific reason? Code requirements vary widely by location. For example, where I live the applicable code is still NEC 2005. In the log house I built I only had to have AFCIs for the bedroom circuits. |
| All times are GMT -4. The time now is 07:24 PM. |
