Hi folks—first post here. I've been replacing all the builder grade electrical in my house with decorative Lutron switches, dimmers, and receptacles. Until now I've had no problems, replacing more than 30 switches and dimmers (mix of single pole, 3-way, and 4-way). But I came across a 2 gang box with wiring unlike anything else in the house. After changing the switches, they no longer function.
The box has two 12/3 and two 12/2 cables coming into it. See picture below:
The single pole switch on the right controls a single keyless fixture in our garage. The 3-way switch on the left controls a receptacle. I connected the wires on the new switches EXACTLY as they were connected to the old Leviton switches (I labeled each wire prior to making the change). Neither the light nor the outlet function after changing the switches.
Notes: There is a black hot wire from the far left 14/3 cable that is connected to the right switch. Also, the 3-way switch does not have a second switch accompanying it. Not sure of the significance of either...:confused:
Again, I connected the wires to the new Lutron switches EXACTLY as they were connected to the old switches. If anyone could help shed some light on this I would appreciate it. I can take more photos if necessary. Thanks in advance!
