Old 05-12-2008, 04:02 PM   #1
Need help to trouble-shoot a circuit problem
Newby here. Have no power to the circuit of my home that controls the outlets in my garage and outside. I tried replacing the circuit breaker. Still no power. Any suggestions as to what I could check next?
Fred
fredcrn is offline   Reply With Quote
Old 05-12-2008, 04:52 PM   #2
Power Gen/RS Engineer
Is there possibly a GFCI as the first (or perhaps only) receptacle in the circuit? If so, everything else is probably coming off its load side.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Old 05-12-2008, 06:00 PM   #3
Yup....GCI outlet is the first thing to look for.
220/221 is offline   Reply With Quote
Old 05-12-2008, 08:46 PM   #4
Unless the house was wired after 1984, then your bathroom outlets probably don't work either...
LawnGuyLandSparky is offline   Reply With Quote
Old 05-13-2008, 09:12 PM   #5
Haven't thought to check bathroom outlets. House was built in 1999. How do I know if I have a gfci outlet?
Fred
Ps...sorry for slow responses, my computer crashed and I have to wait till I can access from work.
Old 05-14-2008, 12:43 AM   #6
Ok, so after doing some research, a cfgi outlet would have a reset button, right? I don't think any of the outlets on that circuit have one. I'll have a closer look in the morning.
Thanks for the responses.
Fred
Old 05-14-2008, 01:23 AM   #7
" Euro " electrician
frenchelectrican's Avatar
If not in bathroom then check few other locations where you normally don't get around many time you will find a hidden GFCI repectale there and sometime will be located next to the breaker box as well.
You may have to move some stuff around so you can see the GFCI receptale. one way or other it will show up.
Merci,Marc
Old 05-14-2008, 04:03 AM   #8
Here is a pic of what you should find.
http://www.electricsupplyonline.com/...sp_w011016.php
Of course may not be this brand but all gfci look pretty much the same. On a side note you may have a gfci breaker in your elec. panel.
BTW I am not promoting either this web site nor brand of GFCI its just to show what it looks like.
rong1 is offline   Reply With Quote
Old 05-14-2008, 04:48 AM   #9
Ok, so if I indeed find one of these, can I just reset the button, or do I have to replace the outlet?
Fred
Old 05-14-2008, 04:53 AM   #10
Fred
Reset the GFCI. However know that in order for the GFCI to reset it has to have power going to it. If is does not reset it could be either 1. no power to it (check this first) 2. bad GCFI then you would have to replace it.
Old 05-14-2008, 05:49 AM   #11
Thanks for the responses. I'll check later today.
Fred
Old 05-14-2008, 11:21 PM   #12
You guys are fantastic. I had a look around my garage and low and behold, there behind a shelving unit full of junk, was the predicted cgfi outlet. Reset the button and we're back in business. Thanks for all who responded and for your patience with the electrically impaired.
Fred
Need a wiring diagram Mooreski Electrical 46 03-12-2011 04:25 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 04:09 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
