Need Help With Separating The Control Of Lights - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-19-2012, 12:32 PM   #16
Mike.G is offline   Reply With Quote
Old 12-19-2012, 12:56 PM   #17
Rewards Points: 2,516
Hard to see where wires are going/coming from. Is it like this?
hammerlane is offline   Reply With Quote
Old 12-19-2012, 12:59 PM   #18
TTW
TTW's Avatar
Does this look right?
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-19-2012, 02:42 PM   #19
Hammerlane has it right. There is also a black wire coming from the top left tube that goes into the tube going to the left and the top right tube.
Old 12-19-2012, 06:04 PM   #20
Regarding the red and blue wire attached to the dimmer. Which wire is always HOT and which wire is only HOT when the switch is on?
Do you know how to determine this?
Old 12-19-2012, 08:53 PM   #21
Get a dvom, one lead on ground other lead on one wire and check for voltage? Then do the same for the other wire? Switch position is a factor of coarse.
Old 12-19-2012, 09:40 PM   #22
Red wire is the hot wire at all times and the blue is hot only with the switch on.
Old 12-19-2012, 10:58 PM   #23
The light I opened is the left light of the right pair.
Here is a quick sketch of my basement's layout.
Old 12-20-2012, 03:52 AM   #24
dmxtothemax's Avatar
Rewards Points: 5,604
Originally Posted by hammerlane View Post
Seems pretty simple...4 lites controled by one switch...question is where is power coming into?
The switch location or is power coming into one of the light locations?
here are a few diagrams I had saved. No ground wires shown for ease of drawing.
What program do you use to make these type of pictures /wiring diagram ?
dmxtothemax is offline   Reply With Quote
Old 12-20-2012, 06:52 AM   #25
I use microsoft paint program, Turn the canvas light gray and get to drawing using the line tool. For the devices I just save piictures and paste them in.
Need help with separating the control of lights-new-20bitmap-20image-20-2-.jpg
Old 12-20-2012, 07:07 AM   #26
So the right switch as you have it labeled controls lites 1 thru 8?
The left switch as you have it labeled controls lights 9 thru 12?
You want the new switch control to control lites 1, 5, 9 and 10?
Old 12-20-2012, 10:44 AM   #27
Correct. The new wall is already in place and I haven't put the drywall on it yet. I'm waiting to get the electrical done.
Old 12-20-2012, 10:47 AM   #28
The left side switch as you have it labeled in the diagram will only control lites 11 and 12?
Old 12-20-2012, 10:48 AM   #29
It will still control lights 11 and 12.
Old 12-20-2012, 10:53 AM   #30
The switch you you showed in post #16....is that the left side switch or right side switch as shown in the diagram
Water Heater gas control valve/thermostat loose connection Claymation Plumbing 0 06-19-2012 02:18 PM
Lights still dimming and flickerin Keisha34 Electrical 18 06-08-2012 11:14 PM
Dimming and Flickering lights in home Keisha34 Electrical 34 06-05-2012 02:22 PM
Landscape lights BlueBSH Landscaping & Lawn Care 2 02-24-2010 09:43 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 11:22 AM
