Need Help Replacing Electrical Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2014, 07:18 PM   #1
Rewards Points: 2
Need help replacing electrical outlet
I am trying to figure out how to replace my mom's electrical outlet for her. She lives in a mobile home and the wiring is a little different. The outlet has 4 little sections each section has 2 holes. For a total of 8 holes. It has 3 white wires and 3 black wires on each side plus a ground wire screwed down. I have a replacement outlet that only has 4 holes on the back and 4 screw sections on the sides plus a ground screw. How am I supposed to wire this. The problem with her current outlet is that is keeps going out and it knocks the kitchen sink light and other stuff off too. If you bump the outlet it will come back on. That is why I need to exchange it.
Any help appreciated!
PS Will try and upload a picture of it later.
joelhart2013 is offline   Reply With Quote
Old 11-10-2014, 08:12 PM   #2
Rewards Points: 3,396
First thing. If you're married remove your wedding ring.
ritelec is offline   Reply With Quote
The Following 2 Users Say Thank You to ritelec For This Useful Post:
CapnHawk (11-10-2014), clw1963 (11-10-2014)
Old 11-10-2014, 08:19 PM   #3
The four or eight hole sounds like the manufacturers design.
The older one you were able to push eight wires into each side. That's called back stabbing.
People frown at that hear
But your allowed to do it. ( if the wire gauge is not too large)
So if it's 14 ( smaller wire ) you can go to the screws for two black and back stab one. Same with the whites. The blacks go to the brass screw.
You could also get two wire nuts and a piece if wire and pigtail to the receptacle
If the wires are 12 gauge you may need to do that.
Old 11-10-2014, 08:36 PM   #4
Msradell's Avatar
Rewards Points: 210
Making a pigtail connection is the safest and best way to do this! Back stab connections are the source of many problems in wiring systems. They can range from minor problems such as loose connections and intermittent circuits, which is sounds like you might have now up to and including fires in the worst case.
The only problem be that in most mobile homes they use very small electrical boxes soapbox fill may be a problem.
Another option may be to use receptacles that have metal plates underneath the screws. In these you can put two wires under each screw, one on each side of it under the plate. This way you would have plenty of room for all the wires you have and box it wouldn't be a problem.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 11-10-2014, 09:37 PM   #5
Was thinking. Check that older receptacle. The wires may be going into the holes in the back but the holes lead to a plate that the screws tighten down and maybe the screws are loose and need to be tightened.
If it's the style.
Edit. Nice catch msradell.
Tags
outlet
new gas range replacing 220v electric, outlet question jeffzap Electrical 7 11-22-2013 12:43 PM
Ground Wire in Electrical Outlet Box - Where does it go? jgiannis Electrical 3 06-19-2012 02:12 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Help with adding electrical outlet bowanna03 Electrical 5 05-23-2010 07:00 PM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 07:59 PM
