Need Help On Outlet Wiring!! - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2013, 11:45 AM   #1
need help on outlet wiring!!
OK, HERE GOES:
I used 12/2 to wire outlets in my enclosed deck.
i think i did something wrong as several (8 outlets) do not work, 3 outlets do.
power wired to junction box:
- used a pig tale as i was connecting two other 12/2 wires together.
- i connected all three blacks together, three whites, three grounds
I don't think that is my problem as one of the 12/2 wires from that all three outlets work.
its the other 12/2 wire that all is attached to doestn work
12/2 from junction box goes to a switch (this swich runs one outside outlet "ghfi", to turn on/off), also another 12/2 wire that has 7 oulets on it is there.
i connected the black from outside outlet to top of sinple pole switch, i then used a pig tale from the black power in from junction and blace out to other 7 outlets for bottom of singple pole switch. i then used pig tale for ground on single pole switch to the other two grounds.
i'm guessing something is wrong with what i did. the outside outlet doesn't work and all other 7 outlets don't work. i have a volt detector to see if wires have power and all the wires beep for power in the lines to and from all outlets (they still exposed as siding not up, easy to check wires). so the hot wire is going through to outlets but is there something i did wrong with the whites or grounds???
i drew out the diagram as i wired it so see what you think
need help on outlet wiring!!-img_1173.jpg   need help on outlet wiring!!-img_1174.jpg   need help on outlet wiring!!-img_1175.jpg   need help on outlet wiring!!-img_1176.jpg
Kansas is offline   Reply With Quote
Old 03-14-2013, 11:57 AM   #2
eastcoastsparky's Avatar
Rewards Points: 150
Can you get a better angle on that switch box i think i see the problem
eastcoastsparky is offline   Reply With Quote
Old 03-14-2013, 12:59 PM   #3
More pics
Another pic
Old 03-14-2013, 01:00 PM   #4
Another pic
Another pic
Old 03-14-2013, 01:02 PM   #5
Last one for now
Let me know if I need to try another angle
Thanks for looking!!!
Old 03-14-2013, 01:04 PM   #6
Rewards Points: 2,512
what the hay is this
hammerlane is offline   Reply With Quote
Old 03-14-2013, 01:07 PM   #7
And seriously. I got lost. I see hots connectected to neutrals and so forth.
But in the spirit of cooperation you most likely have a loose neurtral wire in one of the bundles. Check the bundle of neutrals circled in green.
need help on outlet wiring!!-img_1173.jpg   need help on outlet wiring!!-img_1175.jpg
Old 03-14-2013, 01:08 PM   #8
Lol sorry none of that cross area connected just overlap in drawing, my bad was in a hurry drawing it
Old 03-14-2013, 01:09 PM   #9
Ok I try to draw it again
Old 03-14-2013, 01:12 PM   #10
use larger lines for cables and thinner lines for individual conductors(wires) or go and use microsoft paint and draw as below.
Old 03-14-2013, 01:19 PM   #11
Ok maybe this is better diagram
I used blue color for white wire, orange for ground, black for black wire.
Wondering if it would of been easier to do a junction of the main power to outlets then have another to switch then all done in one spot??
Old 03-14-2013, 01:29 PM   #12
Trying to get pic upright
Trying to get pic upright not working so far
Old 03-14-2013, 01:31 PM   #13
So all outlets on runs "A" and "B" do not work?
Old 03-14-2013, 01:38 PM   #14
As you have it drawn above, all outlets on run "B" should always be HOT and all outlets on run "A" should all be switched controlled.
You must have connected something wrong along the way because the diagram is correct functionally.
Old 03-14-2013, 01:40 PM   #15
Try this, take wire "C" and attach it to point "D". This bypasses the switch and all outlets on run "A" should be always HOT.
Wiring an outlet to a switch, to a light Athens Electrical 5 01-04-2012 08:03 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Help wiring new outlet Wnt2bsleepin Electrical 15 09-08-2011 12:53 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Troubleshooting bedroom outlet wiring? Operator4819 Electrical 15 04-01-2007 09:10 PM
