Need Help With Odd Transformer - Electrical - DIY Chatroom Home Improvement Forum
Old 11-05-2006, 01:03 AM   #1
Need Help with odd transformer
I recently wondered into the world of DIY, and I decided I would try and turn my old OverHead Projector, into a diy lcd one, with a new case and the whole 9 yards.. but @ the same time re using some materials in my OHP.. I have a 3M 2150 OHP, and heres where I ran into my problem, when taking apart the transformer from the light, and the fan inside the projector, I did'nt relize the transformer has nothing written on it for reconnection, I have the part number but 3M does not support this version ne more for some reason.. if anyone could help with which wires go where, I have 1 black wire, 1 white wire, and 3 red wires, the 3 red wires are labeled 3 , 4 and 5..the white and black have no label @ all, the part number if any use is 78-8054-1439-4 and it says Basler Electric Highland, Illinois, BE-22295-001-C14
jSPENCE is offline   Reply With Quote
Old 11-05-2006, 06:57 AM   #2
World famous jerk.
So you went rippin' and tearin' without even bothering to see how it was hooked up before? I say you got the transformer you deserve. Best of luck to you.
mdshunk is offline   Reply With Quote
Old 11-05-2006, 06:59 AM   #3
ahh
Well yes im a dumb a$$ for this sure, but ive hooked up many transformers over the years.. and just figured that it was post leg ground leg and switch leg with outputs all labeled which wasn't the case @ all, ive used a multi-meter on them but can't find out how to check the switch leg wires, soo maybe I did dig my own ditch here =/
door bell transformer install? THEBIGPUNN Electrical 2 09-09-2010 07:01 AM
Can I use lv transformer for coolbox? gord115 Electrical 4 06-23-2007 10:09 AM
dead transformer otis_ofnh Electrical 3 02-11-2007 12:19 AM
Transformer Question Please HELP!! jSPENCE Electrical 1 11-05-2006 06:48 AM
