Need Help, No Outlet Box! - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 03:27 PM   #1
Question
Need help, no outlet box!
I am trying to install a new light fixture in a bathroom. I have taken the old light down and there is no outlet box in the wall. The three cables are just coming through a hole. I figure I can probably mount the light directly onto the wall (like the old light was) but was wondering if there may be an issue with the ground wire if I do this?
Wes448 is offline   Reply With Quote
Old 01-25-2009, 03:33 PM   #2
Rewards Points: 150
What do you mean by an issue with the grounding wire?
Steelhead is offline   Reply With Quote
Old 01-25-2009, 03:44 PM   #3
I would put in a round speedy box. ( round plastic box with wings) Theyre easy to install. The box has arms on it so when you tighten the screw, they swing out against the backside of the sheetrock like a toggle bolt would.
Cut the sheetrock to fit the box. Insert the wires and tighten down. Very simple.
Twist all the grounds together and leave one long and use a ground wire nut so you can ground your new light fixture. The long wire you left will fit through the green wire nut. theres a hole in the middle of it.
All those wires belong in a box.
II Weeks is offline   Reply With Quote
Old 01-25-2009, 05:24 PM   #4
Install a box.
The main purpose of a jbox is to contain the fire if there is a bad/loose connection in the splice. Bad/loose connections can get very hot. If they are contained there is a good chance that the breaker will trip before the studs catch fire.
220/221 is offline   Reply With Quote
Old 01-25-2009, 05:42 PM   #5
Registered User
Termite's Avatar
Yes, this is a common problem. You definately need a box for the vast majority of fixtures on the market (some strip lights are an exception). It is a good idea for safety and it is a code requirement. As stated, installing a new box is really easy to do.
The green wire nuts pictured above are really slick, but you are not required to use that type. Any properly sized wire nut will do just fine.
Be sure to ground the mounting strap for the light that mounts to the box. It has a little green screw that your grounding wire should wrap around.
Old 01-25-2009, 06:12 PM   #6
I suppose this is metallic sheathed cable? If it is armored cable (metal jacket) you cannot use the plastic box only if you have a special bushing.
rgsgww is offline   Reply With Quote
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
Adding garage outlet Shane Electrical 1 02-23-2006 04:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
