Need Help With No Eletrical Box In Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 06-27-2013, 01:53 PM   #1
Question
Need help with no eletrical box in bathroom
We went to change out the fixture in the bathroom of our 48 yr old home and there is no electrical box. There is a sliding bar/brace in it of some kind as shown in the picture. No new light fixture will attach to it. What can we add without tearing holes in the wall? Pictures and details would be very helpful! Thanks in advance.
jbaker66 is offline   Reply With Quote
Old 06-27-2013, 01:56 PM   #2
MarginallyQualified
Rewards Points: 2,464
It's called an "old work" box.
Plastic or metal... but don't hang too heavy a fixture from it.
Old 06-27-2013, 02:07 PM   #3
Thanks, so do we take a sawz all and cut out the bar that I am assuming is attached to the studs then put this in? How much weight would say it could hold also?
Old 06-27-2013, 10:45 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Before you go that route there is a pancake box that can fit on the crossbrace and you will have to punch the centre KO out and screw that fitting on.
Btw is this cable is switched or alive all the time ?
I will post the pancake box what it look like.,
That will give you a idea on that.
Merci,
Marc
Tags
bathroom , drywall , electrical , vanity , wires
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 04:49 PM
Columbus Ohio Basement Full Bathroom -Post-Construction Compliance Hermi14 Plumbing 5 03-12-2013 07:11 PM
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 04:22 PM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 10:14 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
