Old 09-26-2012, 01:50 PM   #1
need help with new wiring, 2 pot lights and switch
i'm moving the switch location and changing to 2 pot lights. is this correct?: from panel 14/2 to switch, then from switch to first pot light then to second? how should they be connected at each point?
TZona is offline   Reply With Quote
Old 09-26-2012, 01:56 PM   #2
I made this drawing for a different thread, you don't have to have a junction box (unless the existing wiring won't reach the switch). Grounds not shown for clarity.
Dave632 is offline   Reply With Quote
Old 09-26-2012, 02:12 PM   #3
so the top left would be the panel?
Old 09-26-2012, 02:21 PM   #4
DIY Enthusiast
sublime2's Avatar
Top left is the JB,top right would be your switch,bottom two are your lights.
sublime2 is offline   Reply With Quote
Old 09-26-2012, 02:25 PM   #5
in my case im not using a junction box, wiring coming directly from the breaker panel
Old 09-26-2012, 02:26 PM   #6
DIY Enthusiast
sublime2's Avatar
Power to the switch? Follow the above pic.ignore the JB.
Old 09-27-2012, 08:53 AM   #7
at switch the two white wires will splice together and get a wire nut, the two black wires will go directly to the switch, at lights black-black and white-white, grounds go together and make sure there are ground wires going to switch and box if it is metal
cort95 is offline   Reply With Quote
Old 09-27-2012, 09:29 AM   #8
Above pic modified to eliminate the junction box.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Help with wiring: 1 switch controlling 2 lights streko Electrical 6 05-02-2012 10:43 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Wiring receptacle > switch > motion sensor lights Van Home Electrical 11 08-10-2010 12:27 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
