-   -   need help with new wiring, 2 pot lights and switch (http://www.diychatroom.com/f18/need-help-new-wiring-2-pot-lights-switch-158066/)
TZona 09-26-2012 01:50 PM
i'm moving the switch location and changing to 2 pot lights. is this correct?: from panel 14/2 to switch, then from switch to first pot light then to second? how should they be connected at each point?
Dave632 09-26-2012 01:56 PM
1 Attachment(s)
I made this drawing for a different thread, you don't have to have a junction box (unless the existing wiring won't reach the switch). Grounds not shown for clarity.
TZona 09-26-2012 02:12 PM
so the top left would be the panel?
sublime2 09-26-2012 02:21 PM
Top left is the JB,top right would be your switch,bottom two are your lights.
TZona 09-26-2012 02:25 PM
in my case im not using a junction box, wiring coming directly from the breaker panel
sublime2 09-26-2012 02:26 PM
Power to the switch? Follow the above pic.ignore the JB.
cort95 09-27-2012 08:53 AM
at switch the two white wires will splice together and get a wire nut, the two black wires will go directly to the switch, at lights black-black and white-white, grounds go together and make sure there are ground wires going to switch and box if it is metal
Dave632 09-27-2012 09:29 AM
1 Attachment(s)
Above pic modified to eliminate the junction box.
