Need Help Moving An Overhead Light - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2011, 03:38 PM   #1
DIY Homeowner
Rewards Points: 79
Need help moving an overhead light
I have an existing overhead light that is not in the middle of the room where we would like it. I have installed a new round junction box in the desired location and have run a 14/2 romex extension between the old box to the new one. The old box is really crammed full of wires and connections. The light fixture is connected to a bundle of 4 white wires on one lead (large red cap) and to a single white wire on the other lead (small yellow cap). I assume that the bundle is the circuit ground and the single white wire runs from the wall switch. But I thought that any white wire running from a switch that might be hot is supposed to be taped with black or red tape. Is that not the case?
Anyhow, I connected the black wire of the extension to the single white. Maybe that makes it right. Any advice? I don't want to create or continue a code violation.
BTW, this light is on a 15-amp breaker, so the 14/2 is to code.
Thanks in advance.
BRO931 is offline   Reply With Quote
Old 04-12-2011, 03:50 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 544
You are correct that any white wire used as a hot should be remarked.
You connected it the correct way.
You can put some tape on the white wire, or use a marker.
New Light Fixture won't turn off Aubullion Electrical 4 02-22-2011 12:23 AM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 11:04 AM
Condensation in overhead light JB Toyz Electrical 0 12-06-2009 02:40 PM
Overhead light not working lesstrang Electrical 4 11-16-2009 08:52 PM
Overhead light w/ switch and 3 recept. how to wire? twilightcall Electrical 8 01-07-2008 04:27 PM
