Need Help With Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 06:32 PM   #1
need help with motor
Hi I have a motor I think it is from HVAC, given to me by a friend and would like to use it on a project, I would like to buy a switch for it and I do not know what to buy and where to buy , color of wires as follow,
white, black,yellow,blue,orange and red..
here is what is written on the template;
1/10 HP 1075 RPM/5 SPEED
115V 8HZ 1.7A 8P 1PH
thank you,
pogie
Pogie is offline   Reply With Quote
Old 03-14-2011, 07:25 PM   #2
joed's Avatar
Rewards Points: 12,028
Go you want to use at all five speeds or will you just pick one and leave it at that speed?
Old 03-14-2011, 07:39 PM   #3
I would like to use all the speed, so I can select according to my load..thanks..
Old 03-15-2011, 09:01 AM   #4
joed's Avatar
Then you need a switch that that has five on positions and a off.
Connect the hot wire to the common of the switch and each of the five speed wires to the other switch connections.
White will be the neutral and the other five wires will be the different speeds. Power between white and any one of the other wires should make it spin.
Old 03-15-2011, 09:02 AM   #5
joed's Avatar
double post for some reason.
Old 03-15-2011, 09:10 AM   #6
Rewards Points: 30
going back to the original post, 8hz, 8p???? is this a 8 hz motor???
bernie
bernie963 is offline   Reply With Quote
Old 04-03-2011, 10:29 AM   #7
Hi, first I would like thank you for answering my questions..finally I got the switch, somebody gave it to me through my wife, the only thing he told my wife is I need ordinary on/off switch for it..well I am new to this, I do not know where to hook the wires to the switch, the switch has 6 terminals each side..on the right side facing front terminal is in series except for one..please can you guide me step by step on how to hook up this switch..included is pictures of the switch and motor wiring..thank you very much for your time..
http://s1086.photobucket.com/albums/...rq5_daw/motor/
Old 04-03-2011, 10:38 AM   #8
joed's Avatar
I can't tell if that switch will work. You are going to need to test it with an ohm meter. Find one terminal that is common and the other terminals that connect to the common one at a time as you turn the switch. It may not even work. I did notice that it says three phase on it.
Help Carrier, Briant Furnance with Variable motor problem ahenderson HVAC 1 12-19-2010 01:07 PM
New fan motor going out? DavidI HVAC 5 06-23-2010 11:38 AM
Air Handler Motor Wiring brando1118 HVAC 13 06-18-2010 12:42 PM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 06:13 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 07:30 PM
