Need Help With Motion Sensor Floodlights! - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2014, 06:04 PM   #1
Need help with motion sensor floodlights!
Hi all, I have just bought motion sensor floodlights and I need to wire them to the front of the house without tampering with the existing non-motion lights(I currently have two lights in the front of the house on opposite sides of the garage door).
How can I do that? I was thinking of:
- wiring in parallel to the exiting light fixtures
- wiring it to the electrical outlet I have outside
Any suggestions?
I have attached photos.
Need help with motion sensor floodlights!-image-3444315483.jpg   Need help with motion sensor floodlights!-image-1240216477.jpg
BryanTobing is offline   Reply With Quote
Old 02-02-2014, 09:38 PM   #2
joed's Avatar
Rewards Points: 11,516
Yes wire them in parallel.
The Following User Says Thank You to joed For This Useful Post:
gregzoll (02-03-2014)
Old 02-02-2014, 09:39 PM   #3
thanks for the reply. How would I go about doing that exactly? And what type of wire? Would it ruin the voltage and watts and all that? Sorry for the noob questions!
Old 02-02-2014, 09:41 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,096
How do you wish to configure them ?
On only when existing lights are on ?
Or completely indipendant ?
dmxtothemax is offline   Reply With Quote
Old 02-02-2014, 09:43 PM   #5
Originally Posted by dmxtothemax
How do you wish to configure them ? On only when existing lights are on ? Or completely indipendant ?
on only when existing lights are on. The existing lights have a switch, and I want the floodlights to be on when my current lights are on. Not independent.
Old 02-02-2014, 10:16 PM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Do yourself a favor, buy a basic home wiring guide. It sounds as if you don't know the first thing about electrical work.
Old 02-02-2014, 10:43 PM   #7
funny you should mention that, I just bought black and decker's guide to home wiring
The Following User Says Thank You to BryanTobing For This Useful Post:
Old 02-02-2014, 11:58 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,852
How and where will you mount them?
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
Old 02-03-2014, 06:10 AM   #9
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
do not wire them without a SWITCH !!!
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
Stubbie (02-03-2014)
Old 02-03-2014, 08:02 AM   #10
I will screw it in to the wall. It comes with mounts. My only problem is supplying the actual motion lights with power. The mounting itself is easy.
Old 02-03-2014, 08:03 AM   #11
gotcha. If I wire them in parallel with my existing lights do I still have to use a switch?
Old 02-03-2014, 08:15 AM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,032
The light should be mounted on an electrical box not screwed to the wall.
Coastal South Carolina
Old 02-03-2014, 08:21 AM   #13
ok I will purchase one. And after I mount it to this box, how would I power the lights?
Old 02-03-2014, 08:42 AM   #14
Rewards Points: 712
This sounds mean, but your skill level doesn't really seem to be up to this project.
Mark
busman is offline   Reply With Quote
Old 02-03-2014, 08:44 AM   #15
Originally Posted by busman
This sounds mean, but your skill level doesn't really seem to be up to this project. Mark
yeah I know. I didn't think it would be this hard to wire lights! Haha. Thanks for the help though guys.
Dual wiring for motion sensor security light ent Electrical 2 09-14-2011 03:00 PM
Motion Activated Light Control Issue mbaudler Electrical 9 12-14-2010 09:52 AM
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 11:16 AM
motion detector wiring (alarm systems) WendyS Electrical 3 02-25-2010 11:39 PM
Motion flood "non-standard" wiring Fishin_Man Electrical 5 01-14-2009 04:20 PM
