NEED HELP: Maytag Dryer 110v To 220v Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 04:07 AM   #1
NEED HELP: Maytag Dryer 110v to 220v outlet
How do I go about rewiring a 220v cord to a 3 prong 110/120v maytag dryer? I do not have 110/120v outlet available, so converting is a must.
yragh is offline   Reply With Quote
Old 03-20-2011, 07:27 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Start over.
What is a "220v core"???
The dryer is a gas dryer that has a standard 120V cord and plug?
And you have a "240v" dryer receptacle and circuit on the wall?
This is not a simple swap out. If you are experienced in basic electrical work you can probably do it, but if not PLEASE hire a pro. This involves splicing #10 wire and working in a live electrical panel.
Old 03-21-2011, 01:37 AM   #3
thanks for the reply.....
yes 220V ....
The dryer is a electric dryer that has a standard 120V cord and plug
And I dont have a "220/240v" dryer receptacle and circuit on the wall
220V line is only available power to our house....thanks again!
Old 03-21-2011, 01:48 AM   #4
JourneymanSteelFabricator
Im not an electrician but Im wondering if you could cut and marrett off one of the hot (black) wires, then use the other hot (black) on one side of the plug (brass) and the neutral on the other side? And of course use a ground. From what I have learned, 220 volt consists of two hot 110volt wires, a neutral and a ground? Can someone verify this?
BCanuck is offline   Reply With Quote
Converting 220v dryer to 110v dbielinski Appliances 17 09-05-2012 05:45 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
220v to 110v extension cord? glamabilly Electrical 14 09-25-2010 11:25 PM
Adding a 220v jointer to a dryer outlet popeka Electrical 7 12-13-2009 09:33 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
