Need Help Installing A Sub Panel Outside Off The Main For Multiple A/C Units - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2012, 04:27 PM   #1
Need help installing a sub panel outside off the main for multiple A/C units
Hi everyone and thank you in advance for the great help offered here!
I currently live in Puerto Rico and houses here are contructed of concrete walls and roofing.
My project consist of adding a sub-pannel to feed 3 A/C units that are located on my roof. I would also like to connect a security flood lamp to it and future expansion for another 2 A/C.
I am including pictures of the main feed that is on the outside wall with the power meter.
I am planing to feed the sub-panel out of the main. The wires will need to run along the outside wall to the roof, and continue in the roof to a central location in the roof that has about 3ft high and 5ft wide concrete wall.
What size (amp breaker), wiring (#8 or #6), and type of conduit should I use?
I am a handyman and are confortable with doing this job.
Thanks in advance.
Need help installing a sub panel outside off the main for multiple A/C units-main.jpg
Need help installing a sub panel outside off the main for multiple A/C units-main-2.jpg
cargarci is offline   Reply With Quote
Old 11-13-2012, 04:33 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
With 6's, you are going to be limited to max 75A.
How much do the AC's draw? How large is the main? What else is on the service (water heater, dryer, range)?
Old 11-13-2012, 04:36 PM   #3
The main disconnect shown in the picture is a 200amp.
The A/C's are 8amps, 11amps and 14amps. Future A/C's would be of 11amps each.
So;
8, 11, 14, 11, 11 for all five A/Cs
Old 11-13-2012, 04:48 PM   #4
Licensed electrician
Rewards Points: 1,256
There is no room to add additional breaker in that meter panel. You will need to come from the inside panel.
Old 11-13-2012, 04:50 PM   #5
How do I do it? the panel is in the middle of the house!
Old 11-16-2012, 12:25 PM   #6
Ok, I am back in business. I found a 1 in conduit that goes from the sub-panel to the roof and is empty. There is also room in the sub-panel to put a double breaker.
The run is about 90ft long.
So what wires should I use #6 or #8 for load and common? Ground #10?
What about breaker size on sub-panel A and A/C loads?
Thanks in advance!
Old 11-18-2012, 08:42 AM   #7
Can someone help determine the breakers and wiring size???
I just need the wiring size and breakers recommendations, anyone please?
Old 11-18-2012, 09:25 AM   #8
Master Electrician
Rewards Points: 3,750
# 3 Cu, 100 amp.
brric is offline   Reply With Quote
Old 11-20-2012, 03:02 PM   #9
I cannot feed 4 #3 wires in a 1 inch conduit???
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 03:09 AM
installing 200A panel 1000 feet away from main 600A rocky69 Electrical 2 09-23-2010 09:15 PM
main to sub panel conduit/wire run daddyrabbit Electrical 7 02-12-2010 08:12 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 06:55 PM
