Need Help With How To Mount Porch Light To Concrete Foundation Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2010, 08:06 PM   #1
DIY Home owner
Need help with how to mount porch light to concrete foundation wall
Ok everybody, I'm at a loss... Here's a little background.
We bought our house three years ago, first time home owners. I'm finishing the basement adding a full bath, bedroom, recroom, and office. Everyone else on our street has a walk-out basement because we're on a hill. We decided to add a walk-out to our house. The area was excavated, new footing and frost wall poured, and door installed by a contractor friend of mine. I built all the retaining walls, and in September had a concrete slab poured for the patio. I want to install a porch light on the concrete wall between the door and window. However, I'm not sure what the correct way of doing this would be. I'm hoping someone here can shed some light on this and point me in the right direction. The concrete wall will be finished using Natural Thin Stone Veneer, so there will be approximately 1-2" of additional thickness added to the wall just so you know. I'm attaching a picture of the walk-out patio and I added a yellow circle to show the approximate location of the light fixture.
I know that by looking at this picture I could just install a floodlight above the wall, but what this picture doesn't show is the 14'x12' deck that I just built over the patio (that's what the stairs lead up to now). I will also be installing the Dry Space system between the joists to keep the patio dry year round so that's why I really need this porch light where I want it.
The foundation wall is 8" thick, and I have not yet drywalled the back side so I have complete access to both sides. I have a switch box nailed in inside and ready to go. Hope someone can help!
Need help with how to mount porch light to concrete foundation wall-porch-light.jpg
wherm5150 is offline   Reply With Quote
Old 11-16-2010, 08:15 PM   #2
Electrician
Rewards Points: 780
You could use a regular octagon which is 1.5" deep(as long as the finish material is thicker than that. Drill a hole through the concrete and fish your wire through the back of the octagon and screw the octagon on the cement wall.
If the finish material is less than 1.5" you could use a pancake box
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
You can also get a pancake extension that will bring it out to 1".
If you go with the pancake box, check your light and see if there is a bolt that goes in the middle to hold the light on. If there is you will have to knock out the middle hole and drill a hole there as well for that bolt will have somewhere to go. Also don't bring your wire in the middle hole, incase there is a bolt for your light.
darren is offline   Reply With Quote
Old 11-16-2010, 08:21 PM   #3
DIY Home owner
Thanks, I have read a little about the pancake boxes... Would I just pre-drill and use Tapcon screws then to hold the box to the wall (whichever box I end up choosing)?
Old 11-16-2010, 08:24 PM   #4
I=E/R
a7ecorsair's Avatar
Is it a poured concrete wall or block? How did you cut the door in? Sounds like you need a hammer drill and a 1/2" drill about 8 1/2" long
a7ecorsair is offline   Reply With Quote
Old 11-16-2010, 08:38 PM   #5
DIY Home owner
It is poured concrete, I have a hammer drill, and I have a 10" long 1/2" concrete drill bit. I've already had to run exterior wire through the wall in a different location, and burried it behind the retaining wall to power the lights in installed in my corner post for the retaining wall.
I guess the most confusion for me on the porch light was whether or not I could surface mount an electrical box, or if I'd have to chisel out an opening in the surface to flush mount the box. That would suck!
I'm cool with surface mounting the box knowing that additional thickness will be added to the wall to basically make it look flush mounted, but as always I'll check with my inspector first!
Thanks guys!
Old 11-16-2010, 09:44 PM   #6
I=E/R
a7ecorsair's Avatar
I'd go for something like this and then dress the surrounding area so it would be flush and set the stone veneer around it.
http://www.homedepot.com/Electrical-...atalogId=10053
Need help with how to mount porch light to concrete foundation wall-round-box.jpg
Old 11-16-2010, 09:47 PM   #7
DIY Home owner
Would that piece come with plugs to thread into the side holes?
Old 11-16-2010, 09:56 PM   #8
I=E/R
a7ecorsair's Avatar
Yup, it's rated for exterior use too.
Fix Drill Holes in Concrete Foundation Wall jdusling Building & Construction 8 08-26-2011 11:31 AM
Remove Switch from controlling outlet/wire wall light to wall switch salesbyashley Electrical 2 08-26-2010 03:07 PM
Concrete Repair Help / Contractor Problems thp Building & Construction 12 09-24-2009 02:01 PM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 02:38 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
