Need Help Honda EU 2000 Generator Wiring Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 11-22-2009, 01:19 PM   #1
Need Help Honda EU 2000 generator wiring problem
Hello All,
I'm having a problem getting my generator to power the lights in my enclosed trailer. When I plug the cord from the trailer into a oulet on the house everything works fine. When I plug the cord into my generator nothing happens. I have a honda eu2000i. My generator has a connection for a ground. I have tried connecting a ground from my generator to my trailer with still no luck in getting the lights to work. The lights i'm powering only take 250 watts to power. My generator is rated for 2000 wattts. So i know the generator has plenty of power. I have checked the generator to make sure it works. I have plugged in a shop vac and a power saw and it works like a champ. If anyone could tell me what to do to get my generator to power my lights I would realy appreciate it. Thanks in advance for any help.
rickytz7111 is offline   Reply With Quote
Old 11-22-2009, 04:56 PM   #2
Idiot Emeritus
Rewards Points: 1,492
Check the neutral and ground connections in the trailer. Make sure that the neutral goes to the neutral prong on the trailer plug.
If these are backward and the generator has a floating neutral, no power will flow.
Rob
micromind is offline   Reply With Quote
Old 11-22-2009, 07:49 PM   #3
I have a 220 style outlet ran to the outside of the trailer. I have a dryer style cord on one end and a 110 male adapter on the other end. I'm only powering 2 flourcent lights. When you say neutral prong on the trailer plug is that the left side of a 220 dryer plug? I have the 110 side hooked up with black on the right side, white on the left side and green on the bottom. Thanks again for any help I hope that I didn't confuse you.
Old 11-22-2009, 08:16 PM   #4
" Euro " electrician
frenchelectrican's Avatar
are you talking about this verison ?
[img]http://images.orgill.com/200x200/6982383.jpg[/img]
or this one ?
Old 11-22-2009, 08:51 PM   #5
It is kind of like the top one. The only diffrence I think is that the ground is completely round instead of having the U shape. But that is very close to it.
Old 11-22-2009, 09:40 PM   #6
Rewards Points: 1,016
This site may help - http://www.myrv.us/electric/
You probably have the 120 volt 30 amp RV service - often mistaken as a 220 volt service.
Old 11-22-2009, 09:42 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
You have something wired wrong. It is NOT the genny.
HOW did you wire a 120v plug to a 120/240v receptacle??? Or do you have a male to male cord???? PLEASE tell me you do NOT.
This whole thing sounds fishy.
Old 11-22-2009, 10:02 PM   #8
Aww Merde ! this is serious stuff I hope you did not transponded the netural et hot conductor this is very serious stuff.
The TT30R et TT30P is straght 120 volts you should not get this hooked up wrong at all
This photo will show clear how this hook up
This photo is correct and you should not have the conductors on wrong spot at all.
If you used the adpator that you need to check it closer to make sure you have it line up correct especally if homemade item that is very serious item you have to pay attetion.
Merci,Marc
Old 11-23-2009, 02:53 PM   #9
Make sure that the cord you are using is the correct cord. you should have a round "twist lock" cord that has 4 wires inside. There is a ground wire (the prong of the cord that has a bent tip) a white wire or neutral and then the black and red wires that are the hot leads. If you dont have the neutral, there is no telling what the trailer will do. You might get a cheap volt meter at radio shack and test between the hot and the neutral and see if you get 115 to 120 volts. You should get 220 to 240 volts between the two hot leads. Google L14-20 or "L14-30 plug" to get a drawing of what prong is what.
Dan Smithson is offline   Reply With Quote
Old 11-23-2009, 03:55 PM   #10
Are you even aware of the actual generator we are talking about????
http://www.hondapowerequipment.com/p...elid=EU2000IAN
Old 11-23-2009, 09:18 PM   #11
I think the adapter the OP has is like this - a common item to enable a 30 amp RV connector to plug into common 120v outlet.
http://www.campingworld.com/shopping...-adapter/47583
2000 GMC savana van headlight problem plumber Jim Automotive Repairs 10 07-24-2012 05:44 PM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
2000 Saturn wiper motor problem ashukoff Automotive Repairs 1 10-02-2008 11:38 AM
2000 Toyota Avalon: starting and idling problem proofer Automotive Repairs 3 09-03-2008 09:29 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
