Need Help, Have A 10 Gallons Nano-LED Setup - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2012, 12:27 AM   #1
Need help, have a 10 gallons nano-LED setup
I know nothing about LED and its hard to research. I have a ten gallon and I want to buy a clip on or LED hood for it. I plan on doing SPS and LPS corals.
I need some numbers for what to look for. I have no idea what kind of watts to get, the size or how many leds to get on the fixture. can someone please help point out some affordable fixtures that would work well on a 10 gallon?? thanks for any help!!
_______________________
led strip lighting
led light
led ceiling fan lights
Elfreda Blau is offline   Reply With Quote
Old 08-11-2012, 10:58 AM   #2
Rewards Points: 204
What are your aquarium numbers calling for as far as lighting? In watts. You need to have a figure before anyone can advise you to what type and size LED you will need. Then all you have to do is figure out how to match the lighting requirement using LED. Google is your best bet.
Maybe use the search term LED watts = Fluorescent watts.
Old 08-11-2012, 01:31 PM   #3
Electrical Contractor
kbsparky's Avatar
You should never search using "watts" for lighting comparisons. "Lumens" is the more appropriate term for an accurate calculation ....
-KB
Old 08-11-2012, 01:52 PM   #4
Rewards Points: 83
Lumens is what you're looking for. Watts is a rate of energy conversion.
Try and find out what you have for lumen output and try to find something similar or better.
Protocol. is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
My Home Video Surveillance Setup. roasted Off Topic 19 08-31-2012 09:10 AM
Need Help Figuring Out Proper Filtration Setup HiccaBurp Plumbing 8 05-08-2012 01:28 PM
Simplify Sunsmart Setup? Ducati Electrical 5 12-17-2011 08:10 PM
home theater setup cannouu Electrical 5 04-09-2008 06:01 AM
