Need Help On A GE Breaker Box Model #TM1615R - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 10:02 AM   #1
Smile
I am wanting to put in a 60 AMP 240 Volt 2 Pole Breaker in my box and at the bottom right I only have it looks like two spots open but not sure if a think breaker will work or if they make a Thin breaker for my box and if they do where do I buy it, I do not care if it is made by GE or someone else just so it would work. I have attached a couple pictures of my breaker box....
Thank you
http://www.flickr.com/photos/77767815@N06/6818368746/
http://www.flickr.com/photos/77767815@N06/6818369046/
http://www.flickr.com/photos/77767815@N06/6964490475/
http://www.flickr.com/photos/77767815@N06/6964490589/
CJ2U2 is offline   Reply With Quote
Old 03-08-2012, 10:05 AM   #2
Rewards Points: 330
your links don't work...
oleguy74 is offline   Reply With Quote
Old 03-08-2012, 10:07 AM   #3
They are working now, I had a problem and reset them.
Old 03-08-2012, 10:12 AM   #4
Ravenworks's Avatar
I did notice a GREEN wire that is connected to one of your breakers.
You need to sort that one out.
Ravenworks is offline   Reply With Quote
Old 03-08-2012, 10:24 AM   #5
Rewards Points: 330
top tw0 and bottom left are full size.looks like you only have room for a full size or two thins on bottom same pole.you might try to make top right a 30 amp thin to free up a slot.
Old 03-08-2012, 10:42 AM   #6
Home Depot carries this breaker would this one work for me on the bottom right of my panel?
http://www.flickr.com/photos/77767815@N06/6818466488/
This is a 60 AMP 240 Volt 2 Pole thick made by GE
Old 03-08-2012, 10:55 AM   #7
joed's Avatar
Rewards Points: 13,338
A thin breaker won't work for what you need. You need a full double pole 60 amp breaker and you don't have space. You can not use the thin twins to replace full size double pole breakers.
Old 03-08-2012, 11:02 AM   #8
So what option would be the best or easiest to go with out having to replace the whole box?
Old 03-08-2012, 11:10 AM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
A slim 2 pole breaker will fit that panel.
If you install it just below the 2 pole breaker on the right side, you will hit both buss bars.
Most of the 2 pole breakers in this panel are single width breakers.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
brric (03-08-2012), frenchelectrican (03-09-2012)
Old 03-08-2012, 11:31 AM   #10
Craftsman
CJ2U2, Go online and search for a thqp260 ge slim breaker and pick who you would like to buy from!
Superrick is offline   Reply With Quote
Old 03-08-2012, 12:03 PM   #11
I looked for a thqp260 ge slim breaker but only can find a thqp250 they do not make a thqp260
Old 03-08-2012, 12:39 PM   #12
Sorry they do not make a thqp260 ge slim breaker only in a THQP250 50 AMP so any other thoughts?
Old 03-08-2012, 01:30 PM   #13
Licensed Pro
Buy a slim 30A double pole to install on the bottom right, move the wiring from the 30A dp on the top right to there, replace the 30A dp with a 60A dp.
The Following 2 Users Say Thank You to HouseHelper For This Useful Post:
CJ2U2 (03-08-2012), jbfan (03-08-2012)
Old 03-08-2012, 01:54 PM   #14
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If they have quad breakers for your panel you may be able to get a quad breaker that has 2 pole 50 amp and 2 pole 15 amp you could shift your breakers up and have a full open spot for a double pole 60 amp breaker.
Call your local electric supply and see what they can get for you.
If you do use a quad make sure that your panel can handle that much per terminal on the buss bar. You may have to move the quad down two spaces and bring two tandems up.
Make sure you find out what your panel is rated for and also how many tandem breakers you are allowed before doing anything. Another option is a sub panel and moving some breakers to that panel.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-08-2012, 02:37 PM   #15
OK I might have it figured out....please look at my picture that is at the link and see if that would work? I have a single pole 15 AMP and if I removed my 20 AMP and put my 15 AMP single pole where the 20 AMP was, which that I only use for my Christmas lights and then move everything up one one the right that would free up one then could I put my 60 AMP 2 Pole 240 volt in....thank you all so much for your help.
http://www.flickr.com/photos/77767815@N06/6818983788/
GE dishwasher model PDW7880G00SS blows the ckt breaker Jason McIntosh Appliances 1 12-31-2011 12:50 PM
Simens breaker Q1520NC Non-Current Limiting Breaker? ericw12 Electrical 3 10-16-2011 01:31 AM
AFCI Breaker Keeps Tripping Muinchja Electrical 30 08-25-2011 04:54 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
