Need Help In Finding 3" Recessed Light Housing For 1 1/8" Inch Ceiling Thickness - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 05:58 PM   #1
Rewards Points: 37
Question
Need help in finding 3" recessed light housing for 1 1/8" inch ceiling thickness
I will cut to the chase. For our ceiling, we are installing a 5/8" dry wall, together with 1/2" soundproofing. This gives our ceiling a total of 1 1/8" thickness.
It turns out that the Eurofase 3" housing that I was going to use is not compatible with anything beyond the standard 5/8" thinkness. Basically, you cannot set the trim properly and it will not snap-in.
After doing much research, I can only find one brand/model which is adjustable for ceiling thickness of 1/2" up to 1 1/2". It is Halo H36TAT. It is sold at Home Depot and I have heard unkind things about the long-term quality of this device.
Can anyone recommend any other brand (model) options that I may have? My wife and I definately want to have the soundproof later installed. We will be using 50-watt GU10 line-voltage lights.
Thank you in advance for your input / advice.
mystiky is offline   Reply With Quote
Old 07-08-2011, 06:06 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 534
Where have you heard about the long term quailty?
I use nothing but halo, but have never used this type, and never had problems.
Old 07-08-2011, 07:38 PM   #3
Licensed electrician
Rewards Points: 1,750
Why not cut a larger hole like maybe 5-6" in the material above the finish drywall? That way the clips only need to grab the 1/2 or 5/8 thickness.
Old 07-09-2011, 06:37 AM   #4
Rewards Points: 37
Unfortuantely, that doesn't work as we have already tried that.
Old 07-09-2011, 10:28 AM   #5
Rewards Points: 37
I guess my electrician "poo-pooed" the brand, but I have not found anything that is bad about Halo myself. I guess the fact that it is sold in Home Depot, it turns a lot of people off.
I guess since I don't have a transformer (since this is line voltage), then I guess it either works or not out of the box.
Old 07-09-2011, 10:42 AM   #6
jbfan's Avatar
Rewards Points: 534
I think you are right about being sold at HD.
That means less quailty for some people, but Halo makes great cans.
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
Ceiling light abuse! shurik57 Electrical 5 11-26-2007 10:30 AM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 06:22 AM
ANOTHER ceiling fan light fixture doesn't work bandguy Electrical 8 06-13-2007 08:40 AM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
