Need Help Figuring This Out - Electrical - DIY Chatroom Home Improvement Forum
Old 12-14-2010, 08:53 AM   #1
Need help figuring this out
Hello, I need some help trying to indentify this .. thing. It came off a fish tank i bought. but before i start looking into another light source, i would like to see if i can just replace this thing.
40gallon is offline   Reply With Quote
Old 12-14-2010, 09:01 AM   #2
joed's Avatar
Rewards Points: 11,980
Looks like a low voltage light system, four light sockets and a power transformer. What is you want to identify?
Old 12-14-2010, 09:05 AM   #3
The whole thing..It is one piece. I've been looking online but i cant find a name for it..need to know where i may find one. and thank you for the response.
Old 12-14-2010, 09:11 AM   #4
The 4 things on the left is where you put in the light bulb.
Old 12-14-2010, 01:34 PM   #5
I'm guessing it fits 2 flourescent bulps although you would usually have a fairly large ballast for a fish tank light....rather than what appears to be a wall wart.
What kind of tank are you putting together (freshwater, saltwater fish only, saltwater reef, etc...)?
jerseyguy1996 is offline   Reply With Quote
Old 12-14-2010, 01:47 PM   #6
the Musigician
DangerMouse's Avatar
Google any and all info on the other side of that wallwart.
Brand names, model#'s, etc.
DM
Old 12-14-2010, 03:42 PM   #7
Jerseyguy..it's a freshwater...a little deep for it to be planted, but i do like to see my fish..
-Is wallwart AKA plug? it has 9707034 handwritten on a sticker..no brand name so i dont know what to search! The caps for the bulbs read either MORE or MOKE..
Man it smells terrible too..all burnt up! Yick
Old 12-14-2010, 07:50 PM   #8
joed's Avatar
Google low voltage aquarium lights. Lots of stuff will come up. Many of them are now LED.
Old 12-15-2010, 08:23 AM   #9
Yes Wallwart is the plug. It will usually have information on it such as the input voltage, output voltage, whether the output voltage is DC or AC, the input AC frequency. It may be stamped into the plastic on the side with the plug prongs or on the side opposite the plug prongs.
So for freshwater you wouldn't expect the lighting to be very powerful. My reef tank uses VHO (very high output) flourescent bulbs which require a special ballast to drive them. I would expect that yours would probably be fairly standard.
Are you located in the U.S. or somewhere else?
Old 01-08-2011, 07:10 PM   #10
Those are weatherproof end caps for fluorescent lamps above an aquarium. Whether they for T-12 or T-8 would be determined by the diameter of the caps. What wattage lamp the ballast could drive is unknown. Maybe that is stamped on the wall-wart. The fluorescent lamps need to be supported by C-shaped lamp clips, fastened to the aquarium lid.
Grounded-B is offline   Reply With Quote
Figuring HVAC Needs in Basement cdhen14 HVAC 12 06-03-2010 07:26 AM
Newbie: Help figuring out dimensions konboy22 Carpentry 11 09-23-2009 12:03 AM
Timer Box -- Need help in figuring out proofer Electrical 9 08-13-2008 12:58 PM
Figuring out valve functions yassers Landscaping & Lawn Care 2 06-22-2008 01:37 AM
figuring what tons are needed pbuzz3323 HVAC 2 07-31-2006 07:40 PM
