Need Help With A Failed Close Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 10-03-2009, 07:31 PM   #1
1geo
1geo's Avatar
Need Help with a Failed Close Circuit
I have a need for an alarm when the house power fails. I bought a sump pump alarm. The float switch is open when the water is low and closes when the water is high. So I need a simple circuit that stays open when house power is on and closes when house power is off. This way I can hook up the sump high water alarm to the circuit and when house power fails it will alarm. Can any one help with a schematic of such a circuit?
1geo is offline   Reply With Quote
Old 10-03-2009, 07:45 PM   #2
Couldn't do it with one relay.
A is a battery operated alarm.
The 120v relay coil across the water level switch needs to have an impedance much higher than the motor impedance when stalled. 100 ohms or more should do it.
Hosfelt probably has all you need.
Old 10-03-2009, 07:54 PM   #3
What voltage do you need for the alarm?
hayewe farm is offline   Reply With Quote
Old 10-03-2009, 08:49 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by 1geo View Post
.... I bought a sump pump alarm. The float switch is open when the water is low and closes when the water is high.....
What alarm did you buy?
Please include model number, and what type of signaling device you plan to use e.g. Warning light, horn, telephone dialer etc
Disclaimer
& Stay Safe
.....Bob Lavery
Replacing a circuit breaker tertius Electrical 9 09-24-2009 09:17 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
GFCI and Smoke alarm circuit issues 00u6166 Electrical 9 10-30-2007 03:41 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 04:09 PM
Conflicting Circuit Info!?? BenBil Electrical 9 01-15-2007 09:26 AM
