Need Help...existing Wiring. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 11:41 AM   #1
Rewards Points: 204
Need help...existing wiring.
I am finishing my basement and I am removing the existing builder bare lights. They have 2 3-way switches (one at the bottom of the stairs and one from the outside walk out) controlling 3 lights. The 3-way by the indoor stairs has a single 14-3 cable running to the other box (by the walk out). I went to open the other box (by the walk out) and this is what I found and it confuses me. This is a double gang box with two switches...one 3-way for the inside lights mentioned and one for the outside light.
1. The box has two 14-3 cable and one 14-2 cable running into it. The 14-2 is to the outside light. One of the 14-3 wires is ran to the other 3-way switch...by the indoor stairs and the other 14-3 is run up to the light. The way it is wired is confusing to me and I need help figuring it out. See next pic.
2. The switch on the left is the 3-way and has a red from each 14-3 cable connected and the white. The switch on the right is a normal 2-way for the outside light, but they have it double blacked (which I thought was against code) at the bottom terminal one being the "hot" feed and the other black going to the other 14-3 cable.
3. Here is a better shot of the wires. The unsheathed looking ones are going to the outside light, I am guessing the sheathing is up in the conduit.
I need to get rid of the 3 way switches and unneeded cabling and keep the path intact because this circuit also powers my blower for my fireplace directly above this.
Any wisdom or help is GREATLY appreciated.
Thanks, Joe.
Abs777 is offline   Reply With Quote
Old 12-01-2010, 12:58 PM   #2
Rewards Points: 204
Any ideas?
Old 12-01-2010, 02:00 PM   #3
Just over one hour and no response. A little impatient are we?
oberkc is offline   Reply With Quote
Old 12-01-2010, 02:37 PM   #4
Rewards Points: 107
3-way
3Ways are feed from either switch, Black screw at one end gets feed, the other end goes to light, travelers don't matter, its so simple once you see it. the N gets wire nutted straight through.
jerzeedivr is offline   Reply With Quote
Old 12-01-2010, 02:45 PM   #5
Rewards Points: 256
Turning 2 three way switches into 1 regular switch is easy, but I'd question why you want to do it.
You need a switch at the top and bottom of the stairs.
If you are replacing the light fixture, why are you touching the switches?
Am I misunderstanding what you are asking?
michaelcherr is offline   Reply With Quote
Old 12-01-2010, 03:01 PM   #6
Rewards Points: 204
I don't need the switches anymore, I am removing the lights. I have put cans on new switches down there. I know how 3-way switches work, I have never seen it ran through 2 separate 14-3 cables and was wondering if this was normal.
Old 12-01-2010, 03:05 PM   #7
Rewards Points: 256
What will light up the stairs now and how is it switched?
Old 12-01-2010, 03:15 PM   #8
Rewards Points: 204
I am converting that to a single gang box for the stair lights. I am just trying to figure out what to do with the two 14-3 cables. Thanks
Old 12-02-2010, 09:45 AM   #9
Rewards Points: 204
This is resolved. Thanks.
Tying in wiring to existing ceiling light samson115 Electrical 3 11-22-2009 12:12 PM
replacing old wire on existing circuits... red86yota Electrical 9 12-08-2008 06:00 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 11:16 AM
Permit application harder than the wiring job itself - WA State blschmitz Electrical 2 01-18-2008 07:36 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
