Need Help With This Diagram - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2008, 09:15 PM   #1
jelly's Avatar
Rewards Points: 330
Need help with this diagram
I updated an outlet but I do not remember how it was wired. That facts:
1) two wires were nutted and stuffed in behind the outlet.
2) three wires were connected to the outlet
Can you help pair the wires?
jelly is online now   Reply With Quote
Old 11-15-2008, 09:19 PM   #2
Rewards Points: 2,350
Wire the two white wires together, then take a short piece from them to the silver screw on the receptacle. Wire the two blacks together and pigtail to one of the brass screws. Break the tab between the brass screws and connect the red to the other.
Old 11-16-2008, 06:44 AM   #3
jelly's Avatar
Rewards Points: 330
hi inphase, the old outlet did not have any pigtails nor was the tab broken but i'll give it a shot. thanks
Old 11-16-2008, 07:08 AM   #4
Whatamess
If what inphase suggested does not work check voltage on the wires and re post.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 11-16-2008, 08:49 AM   #5
jelly's Avatar
Rewards Points: 330
Thanks guys, worked like a charm.
Have a great day.
Old 11-16-2008, 10:21 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
That's because before the whole outlet was switched. The way Inphase told you will only switch half, which IMO is better. How often will you have TWO lamps plugged in? Now at least you have use of the other receptacle.
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
wiring diagram question screenporch21 Electrical 10 11-30-2008 09:14 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
Does this wiring diagram work? beezlebub03 Electrical 7 05-05-2008 12:54 AM
